monitor audio rx6av12 or monitor audio apex 5.1?
6 replies [Last post]
markyboy156
markyboy156's picture
Smile hi what would people recommend either the monitor audio apex package but using a b&w pv1d sub instead of the aw12 or monitor audio rx6 av12 package what would give the better sound scale and bass and speed i want to use it for 50% movies 30% music 20% games need help asap please ohhh sure
greedy
greedy's picture
RE: monitor audio rx6av12 or monitor audio apex 5.1?
Hi, depends on your budget..which amp do you have?Sound depends not only from the speakers:)
__________________
Monitor audio Apex5.1, Denon AVR-4311, Dune SmartHD1,Playstation3(FATboy), Synology ds411+II(ultrasilent, fans modificated by me),Chord Odyssey2 cables. will buy panasonic plasma wowCool
spr1ggsy
spr1ggsy's picture
This type of query has always flummoxed me. How the hell can another persons ear tell you what you would or would not prefer?
THERE IS NO CORRECT WAY FOR THINGS TO SOUND LIKE : IF SO EVERY HIFI  OR av SYSTEM WOULD SOUND THE SAME!
The only way is to actually listen to the stuff yourself from a local reputable dealer and make up your OWN mind.
It requires effort and a bit of time but in the end its worth it. You wouldnt buy a car without test driving it or recommend a curry without tasting it first would you?
The main problem is that independant hifi stores are closing down left right and centre due to people not supporting them and blindly buying whatever "gets 5 stars" at the best price they can find on the internet.
markyboy156
RE: onkyo 5009?
Smile hi i have a onkyo 5009 and the budget doesnt matter banging head against wall banging head against wall
David@FrankHarvey
David@FrankHarvey's picture
With a 5009, you'll get a fuller sound, better scale, and higher volume levels from the RX package, but the smaller Apex package will be more 'manageable' in a room as far as the sound is concerned.
Between those two packages, the Apex will be more suited to movies and gaming as far as detail and speed is concerned, and the RX package more suited to music. You could combine the strong points of both and go for something like the RX1's or RX2's all round and make a package based around those.
It will depend on how you like your sub bass too - the PV1D is excellent for being more subtle and tighter with good speed, but it won't have the depth and scale of a larger, more capable subwoofer.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
bigboss
bigboss's picture
Why not the AW12 subwoofer? It's absolutely brilliant, & was better than the PV1 subwoofer when I demoed. I can't comment on the PV1D as I haven't done a head to head comparison. Don't write it off without a proper demo.
__________________
michael hoy
michael hoy's picture
+1 on the AW12.
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
