Pioneer SC-LX83 and iControlAV Problem
5 replies [Last post]
ahill698
ahill698's picture
Hi can anyone help?
I would like to control my Pioneer SC-LX83 Av with the Pioner iControlAV iphone, ipad/ ipod app. But no matter what I try i cannot get it to work.
The error I get most is B27102, does anyone know what this is? this is from whatever device I use.
However when I use a new version of icontrolavv2, the app see's the LX83 but gives the error NoN Controllable Device and gives a link to the original app.
I have tried re- booting several times in different orders but to no avail, my BT homehub can also see the LX83. I have also set the ip address manually to aviod that issue.
The reason i want to control it this way is so I can have music in my garden / decking as an extra zone or B speakers without the need to purchase another amp just for the garden. All of my music is on itunes/ipad/ipod/iphone/ATV and the wireless works fine in the garden for these devices to act as a remote.
michael hoy
michael hoy's picture
RE: AV receivers
Found this on amazon's web site;
Ok, I got it to work! I sent Pioneer support an email and this was their response which worked perfectly:
"Thank you for contacting Pioneer Electronics, Inc.
Recommended Solutions:
Turn on the Pioneer receiver. Make sure that there is an ethernet cable connected between the Wi-Fi router and the receiver. Make sure there is no firewall preventing access. Unplug power to the router, then turn power off to the receiver and lastly get out of the iControlAV application. Plug in power to the router and wait a minute, then turn on the receiver and wait 20 seconds and lastly run the iControlAV application. Make sure that the receiver can see the Wi-Fi router, to check network settings in the receiver go into the "Home Menu", "System Setup" then Network Setup."
Once I turned of my wifi firewall and rebooted everything, it worked perfectly.
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
David@FrankHarvey
David@FrankHarvey's picture
RE: AV receivers
Tried mine yesterday which didn't work (the normal iControl app worked fine), but will try the above tonight when I get home.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
michael hoy
RE: AV receivers
David,
Did it work?
__________________
David@FrankHarvey
RE: Pioneer SC-LX83 and iControlAV Problem
Sorry Mike, been really busy recently so haven't had a chance to try it. I will do when I get some time! Smile Although, I assume the OP is talking about the iControlAV app, not the iControlAV2 app - the AV2 app states on my iPad that the 83 can't be controlled via the app when I try to connect.
__________________
drift
drift's picture
RE: AV receivers
I contacted Pioneer support for this same fix.  My icontrolav app had worked previously and stopped a few months ago.  I did not change my firewall settings but completed the power cycle as described and now it works great.  I figured because it had worked previously and I had not changed equipment it was not likely to be a firewall issue. Make sure you follow the steps as described.
