Optical or HDMI?
Hi folks,seem to have got myself a bit of a dilema
As we all do,i want to get the best SQ from my system.
While watching BBCHD,my avr instead of displaying DD,switched to DD EX which i have never had before.
I have the imput from the sky box to the avr set as auto,but having reset to optical i'm getting DD EX.
Dilema is what will give me the better SQ?.....i listen in 5.1 with the simulated front pressence speakers on(dsp).Can't make up my mind as to which i prefere(HDMI/Optical),they sound completley different,but i like both
Also,what would you recomend for say a 7.1 Master audio,straight 5.1 or use the avr's dsp to simulate the front pressence speakers?
Would realy appreciate opinions on this.
Optical or I prefer digital coax. If u have been using HDMI from Sky then no wonder it sounds poor !
Sorry,i have the sky box set to optical out...the avr set to auto.
i'm using both optical...DD.....and HDMI....avr dsp,just can't decide which i like best,for stereo sd broadcasts i prefere the avr dsp,but for 5.1.......
What do you guys prefere?
Personnally i use the least processing when there is a good source. Suck and see is the best oprion. Certainly with bd 5.1 or 7.1 less is more unless yr system & room need lots of eq. I dont think therw is much stereo on tv??? All dolby pro logic at min surely. Or are you talkin music cd?
I mean while watching the bbc news in standard defanition the sound output is stereo,so i find the avr'd dsp to be better.
It's the HD broadcasts i can't decide on,either 5.1 DD....7.1 DD EX....or use the avr's dsp via hdmi,iv'e had the avr audio input set to auto so on the main iv'e been using HDMI...was just wondering how others use there avr
Bottom !! Just lost all my text !
I think the min Sky broadcast to is Prologic so using STANDARD dsp is right for the news. Occasionally a broadcast may benefit from another dsp but I rarely use them.
Other Sky broadcasts (Films and most of Sky1 etc etc) broadcast in Dolby Digital 5-1. I always use STRAIGHT but an occasional program may sound better with dsp.
For DVD or BD in 5-1 or 7-1 (WARHORSE) I always use PURE but if quality is poor then STRAIGHT.
All this is my opinion and depends on room acoustics and broadcast quality etc.
I dont understand where the HDMI issue comes in unless you are using analogue inputs??
if i use auto imput from the avr,it shows as PCM Dolby PLII Movie.....(HDMI)
if i select optical imput from the avr it shows DD EX.
What i can't understand is why in auto,the avr chooses to send sound via hdmi instead of optical(and the correct...but having got used to that i will perservere with DD via optical,although a little louder,and wider it does sound a bit thinner compared to PCM.
if i press the pure button while watching a bd,the sound stays but the picture disapears....so will have to settle for straight.[edit] just adjusted the pure direct mode to display audio
thanks for your patience.
I aint arf confused !
1) Have u got a picture now with yr bd?
2) Are we talking Sky here? Because Sky will not send anyhing but stereo to yr AVR (PCM I think) so anything on sky must use the optical or digital coax.
3) Maybe the (HDMI) refers to the video output - not sure where the 'auto' is set? Usually 'auto' means that it chooses which HDMI the input is from.
4) I think DD Ex shows up if I select STEREO enhanced - ie its not an input but a decoder selection.
Hope this makes some sense !
Just thought have u set for amp to pass thru - check in manual else let us know yr connections eg ...
Sky box HDMI to amp HDMI 1 and optical to AV1
DVD player to HDMI 2
Amp out to TV HDMI 1 etc
cheers
sorry to confuse you Robin.....
the avr audio select can either be set to...
auto..
hdmi....
optical/coax...
analogue.
i usualy have it set to auto,but this gives pcm when watching sky,now it's on optical which shows as DD EX on avr.
it is set up to pass thru,hdmi to hdmi1,optical to av1.
auto..
hdmi....
optical/coax...
analogue.
I'm struggling to understand why you're questioning this still (that's the polite version), stick it on optical/coax and just leave it alone, you'll get the best possible sound quality in any given situation, if you put it on hdmi or auto you'll be missing out when proper DD is being broadcast.
Downloaded yr manual now. Similar to mine. P33 suggests AV3 for yr optical.
P87 u are looking at yes.
Must have a shower but I'll be back
well you can say what you like,polite or not.
my question was what are others using, their avr's dsp or dd.
i have googled about dd ex and my confusion lay in the fact that it was bought out years ago,now i understand that quite a few others have noticed sky hd are using it as opposed to dd.
sorry for clogging up your forum brother,and i'm not whinning or whinging as you put it but trying to understand something that is new to me.
It's fine Robin,i have the optical cable selected and is working...thanx for your advice tho.
my pleasure but all willnot be well with av1methinks.
good luck & keep usinformed
cheers
I am no expert but I do have a Yamaha amp. Some seem not to
iv'e tried selecting other inputs,but the only imput that gives dd is av1.....i will get the cd manual out tmrw and read through again and if i do need to change i'll let you know.
glad you told me about the pure direct by the way,had a look at the imput and video wasn't selected....
- Login to post comments
If you are using HDMI out from the sky box then you will only output stereo, the optical lead will allow DD.
AV System - Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
