Needle Wear?
Sun, Nov 8 2009, 11:02PM
I have the Rega Bias 2 and I was wondering after how many hours of play should I replace the needle?
Mon, Nov 9 2009, 12:21PM
#2
youll hear when you need to do it as the sound begins to blur slightly
Mon, Nov 9 2009, 1:12PM
#3
We tend to find it's about 1,000 to 1,500 hours depending on localised conditions. Cleaning fluids also, generally, reduce the life of the cartridge.
Wed, Nov 11 2009, 7:59PM
#4
Why do cleaning fluids reduce the life of the cartridge/stylus?
Thu, Nov 12 2009, 12:59PM
#5
They're seldom as pure as suggested and start to corrode the cantilever, react with the suspension or reduce the effectiveness of the cement that holds the stylus in place.
Normally somewhere between 750 and 1000hrs I would say.
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
