65 posts / 0 new
Last post
admin's picture
Last seen: 1 day 21 hours ago
Inspire Upgrade
While I’m fitting the Inspire HiFi Quest upgrade to my P3-24
(did I say its coming tomorrow!!! :bounce: ), would
any of the below mods be worth doing at the same time:
1.
Rega white Belt £21
2.
IsoKinetik ISOvert Rega Tonearm VTA Adjustment Kit
by ISOkinetik
£24.99
3.
Origin Live - Rega RB 250/300/600 VTA Adjuster
by Origin Live
£24.98
4.
IsoKinetik ISOweight Upgrade Rega 130g Counterweight
by IsoKinetic
£49.99
Or any others you might recommend.
At this moment I will keep cartridge(Elys 2) as its only 8mths old (used approx. 20-50hrs a wk)
Looking at GOLDRING 1042 as replacement in future.
Cheers in advance
Al ears's picture
Last seen: 18 hours 5 min ago
RE: Inspire Upgrade
Basically the answer is No.
Unless you suddenly want a cartridge change to something like an Ortofon Cadenza then you should not need any VTA adjustment gizmos.
The drive-belt you have should be perfectly fine assuming you have not had the deck for ages. If original belt has become overstretched then maybe just replace it with another belt. I never could see any benefit from the white belt on the Planar 3 I used to have.
With your current cartridge the original balance weight is fine. (If you do plan to run heavier cartridges in the future then i would recommend the Michell 'underslung' counterweight.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
DandyCobalt's picture
Last seen: 1 year 8 months ago
RE: Inspire Upgrade
My suggestion would be to do the Inspire, and see how that all sounds.
Then you can tweak at leisure later, and be able to see if any improvement with any tweak.
Ps. The 1042 is an excellent cartridge - had one before going moving coil route.
Anonymous's picture
RE: Inspire Upgrade
Cheers Alears and Dandy those were my initial thoughts but thought I'ld ask.
CJSF's picture
Last seen: 1 week 4 days ago
RE: Inspire Upgrade
Mmm . . .  :?  Had a look at the 'Inspire' web site, they dont mention the sub platter.  If you are keeping the original SP, there is a problem, the originals were deliberatly over size, making for a more livley sound.  I have heard verious 'not any more' stories? As my Rega is fairly modern a late P5, I measured its SP and it is oversize compared with the metal version I now use.  A replacement metal sub platter is an improvement IMHO, if you are on the upgrade trail,  I use the ISOtech GT offereing + Ruby bearing.  I upgraded to the 'white belt', tried it against the PSU, had similar affect on sound presentation, so opted for the cheaper option, found the PSU induced a slight hum as well
There is a damping kit for the standard plastic SP, that works OK'sh, if you remove 2 or 4 sections, cant for the life of me remeber the name of the supplier, its was £15 from the 'Bay' a good investment at the price, but the full metal SP is the best way but much more expensive.
I found under slung arm counter ballances worked well too.
CJSF
Anonymous's picture
RE: Inspire Upgrade
CJSF
Cheers CJSF will look into thanks
CJSF's picture
RE: Inspire Upgrade
Something else Andy, I have messed about with heavy 'record clamp pucks' as well.  I found them to be inferior sound wise, compared to a light Mitchell type screw clamp, thats on my system.  I dont use an acrylic patter, prefering the standard glass with a 3mm acrylic mat.  Here, I feel we are getting into the relms of likes and disslikes rather than better or worse??  Try clamp, no clamp, the problem is, no clamp means the record can slip especialy with a warped disc, reduces the contact area.
personal choice . . . CJSF
RE: Inspire Upgrade
Problem with the screw clamp (I have a michell version for rega) is that you have to turn off the t/t to flip the vinyl.
I've got the Inspire puck and it works fine. A heavy bit of gear and care when on the Pinot.
Al ears's picture
RE: Inspire Upgrade
Agree a puck type weigth is more convenient than screw type clamp.
Careful on the Pinot DandyCobalt... too much and you'll need to be considering an auto-changer. :grin:
RE: Inspire Upgrade
Ah yes... Mrs C. Wink
Don't have to get up to change records.
CJSF's picture
RE: Inspire Upgrade
Question: . . . have you actualy done an A,B comparison between puck and screw type, if you have and  you cant hear the differance, all well and good?  On my system it was obvious the lighter screw clamp retaind an openess in the music, the puck tended to sit on the music. I'm not prepared to compromise that little extra SQ . . . off with the cover, back on after the session, it take 5 seconds.  Also tried the same at a music dem a while back, the person in the know was a little suprised at the results.  At that time I said the Rega cover has an effect on the sound, laughs all round . . . we removed the lid from its slide hinge . . . the laghing stoped.
My sugestions are not going to make big changes on their own, but as a whole, represent a significant move forward in sound quality . . . thought and attention to detail is what it is all about, attention to detail!
CJSF
Anonymous's picture
RE: Inspire Upgrade
Cheers for all the advice.
Well it arrived to day, had a look in the box and all looks good.
On nights so will do the mod either Sunday or Monday.
At this moment I'm just going to do this upgrade and hear the difference.
I will compare glass and acrylic platter and weight plus no weight(never used a clamp before)
The metal sub plater intrigues but have had a vinyl spending spree so will have to wait.
Thanks again all can't wait to get stuck in swapping everything over.
RE: Inspire Upgrade
Pics please - when you have time. Smile
Would be useful for others to take a few during the makeover process?
Vinyl equivalent of Gok Wan
Sospri's picture
Last seen: 1 year 11 months ago
RE: Inspire Upgrade
I have done this replacment Inspire plinth on my Rega p7, and am very pleased with the result.
Its easy to do if you are handy with a few tools, and if you have a problem Robert is always at the end of the phone...........
Anonymous's picture
RE: Inspire Upgrade RE: Inspire Upgrade
No problem with taking photos, just chilling now tho as finished nights but don't like to sleep
during day on Friday, but don't want to concentrate on fiddly upgrades.
Work tomorrow so Sunday looks promising for makeover
Anonymous's picture
Cheers not bad with tools, time served apprentice. Although spend my time programming robots
for a living now, so less tools, but triumph herald in garage to keep tools busy.
Pages
Log in to post comments
