29 posts / 0 new
Last post
micks_address's picture
Last seen: 2 years 8 months ago
Monitor Audio R One HD versus R225HDS
Hi Folks, To allow me to upgrade screen size from 42" to 50" I'm looking at relacing my left/right R225HDs with an R One HD Here's my current (yes very cramped) set up.
If I get rid of the left/right speaker, I could probably fit the soundbar under the new screen. Now what I'm worried about is that I'll get a big decrease in stereo performance with the soundbar. I use a Denon 3310 and listen to mp3's from my Oppo Bd93 and more often vinyl from my Project Turntable. As demo's a hard to get over here, I was wondering if anyone had any experience of the R One HD when used with stereo music ? I use a RSw12 subwoofer. Cheers, Mick
Pic sorted - mods.
Leeps's picture
Last seen: 6 days 17 hours ago
RE: Monitor Audio R One HD
Hi Mick
I have a Radius One HD, but I choose not to use it for stereo duties.  It's great for movies; incisive, sharp with good steering effects, but I prefer to use the Zone 2 of my AV Receiver to feed some conventional bookshelf speakers (Ruark Epilogues) which are immeasurably better than the Radius One for stereo - it's hard to believe they're running off the same amp.  You can try using the 'Extended Stereo' mode on your AV receiver to spread the sound across all available channels, but that's not a genuinely hi-fi solution.
The reason I like the Radius One for my situation is also for space.  The intention is eventually to purchase a Naim Unitilite (or similar) to feed my stereo speakers (currently on Atacama stands left and right of my TV) then leaving my Zone 2 of my AV receiver free to go from 5.1 to 7.1 with the Radius.
It may not work for you, but if you had Radius for cinema duties like me, could you look at getting some high-performance mini monitors (like my favourite Neat iotas) off your AV receiver's zone 2 for stereo duties and wall mount them?
Ultimately, this could simply be too high a cost to pay for your larger screen size.  Sometimes, it's better to put the sensible hat on and fend off 'upgradeitis'!!
Leeps
Tidal, Cambridge 640CD, Pioneer BDP450 Bluray, Pioneer VSX-2021 AV receiver, Ruark Talisman III, Ruark Dialogue II centre, Ruark Epilogue II rears, MA R370HD sub, Panasonic TX-P42G30B plasma
Leeps's picture
RE: Monitor Audio R One HD versus R225HDS
PS...
Just noticed your signature more carefully.  Why don't you try as a test using your R90HD's so play some stereo music?  The Radius One is essentially a couple of R90HD's at either end with a R225HD in the middle of one cabinet.
This would give you a good idea of how stereo music sounds, although make sure you keep them both close together.  From memory (I'm at work in lunch break right now), the Radius is about 500mm wide, so set them up within that width.
Happy experimenting!
Good thinking that will be my first step! I do have a Denon DAB 38 mini hifi in an ajoining room which i have some boston acoustics a26s connected to. I've been toying with moving the turntable to that room as an alternative
XMB
XMB's picture
Last seen: 5 months 7 hours ago
Why not just mount your current left and right speakers further apart, as you seem to have pleant of space? Don't be too frightened to have them quite a distance from the TV, even if they are not symetrycal, as the surround amp and centre speaker will create a prper sound field. Then when listening to stero sound you will have a better image. This solution will also save you some money!
You can easily try it out as a tempory measue to see how you get on.
i dont have that much space
i dont have that much space unfortunately, I could move the right further towards the wall, and move the left out a couple of inches.. but its going to dominate the room and my wife wont go for it, the thinking behind going for the soundbar is the footprint of the new tv would essentially the same as the current one plus the speakers that are there. Also my moving the left speaker much out its going to overhang the turntable so will have trouble lifting on/off the dust cover
bigboss's picture
Last seen: 6 days 18 hours ago
I think R One HD is the best compromise in your situation. It performs very well.
Thanks bigboss, for the moment i've put my 225s up for sale locally, ill demo the r90s for stereo over the weekend to see how they go. Im letting the 225s go got about 125 pounds each which i think is fair value but no bites yet!
sta99y's picture
Last seen: 8 months 2 weeks ago
can I ask where there advertised??
edit: I see they sold!! Peebs got a good deal.
Yes hopefully he enjoys them as much as i have!
The tv looks naked now with no speakers around it, but strangely almost bigger! I'll be ordering the R One HD towards the end of the month, then probably replacing the tv towards the end of the year. I'll hang on for the ranges to bed in, problems to surface if any and see whats the best option... im leaning towards a 50" VT60 though.. anything bigger would be to much.. think it will be a nice upgrade to go gtom 42" to 50" hopefully the downgrade in speaker quality (maybe) will be worth it for a bigger screen. Which lends itself to an interesting question. Would you rather have a bigger screen with slightly less in the audio department or smaller screen with the best audio you can buy?
Cheers,
Mick
bigboss's picture
Go for the largest screen you can afford, as long as the viewing distance allows it.
Hi Guys,
So todays Im placing the order for my R One HD. Couple of questions. I'm guessing that though its a single unit, it has three sets of speaker connections so I can just connect up the left/center/right speaker wires that I have from my receiver to the R One?
The other question is re isolation. I'll be placing it under the tv on a glass shelf. Should I try and put something like foam or a dampening material between the speaker and the shelf to help with vibrations through the shelf unit?
Cheers,
Mick
Leeps's picture
Hi Mick
Yes, there are three sets of speaker connections, although they're all fairly close together near the centre of the unit.  As far as isolation is concerned, the Radius One comes with rubber feet you can stick on.  (There's also the alternative of wall-mounting, but I appreciate that's not suitable for your corner placing).
My only concern about the rubber feet is that the speaker sits completely flat.  This is fine if the speaker's pointing at ear height, but not ideal if it's pointing at your knees, so you might want to experiment and listen to it in situ before sticking them on.
Hope you're happy with the results.
Leeps's picture
Interesting link Mick - I haven't seen those before, but might be tempted to give them a try myself.  My Radius One is sat on the front of my AV cabinet, which is lower than average, so these could improve things.
Certainly worth experimenting - try it flat initially before you stick the self-adhesive rubber feet on and see what it sounds like (perhaps with some impromptu spacers to lift them off the shelf; there may be a little bass boom but I would imagine that the tweeters are the most affected by the exact attitude of the Radius One).
If you do decide to get the foam wedges, I'd be interested to know how you get on with them and how well they fit the Radius One.
Well eventually my R One HD has arrived! I had to wait over a month for it as I negotiated a very keen price which was based on my retailer being able to include my order with another order from Monitor Audio and as the second order didnt ship till this week I had a long long wait!
http://i40.tinypic.com/2iw0eg9.jpg
Very happy with it.. I've only had the TV speakers for use for the last month and what a difference a proper speaker makes! The R One HD is a lovely neat solution and fits in grand under my TV and is roughly the same width as the TV so looks like it was made to fit!
Listened to some vinyl last night and the stereo sound using my av receiver is pretty great.. no real pereceived downgrade from the R225s I had for left/right.
So far very happy!
Thanks for the help/advice
Cheers,
Mick
Pages
Log in to post comments
