Which cables do I need to connect my speakers to my amp?
7 replies [Last post]
Dariuz
Dariuz's picture
Hi, I ordered the Wharferdale Diamond 121 speakers, (http://www.youtube.com/watch?v=bzfnvOATX70) and will be ordering the Rega Brio-R integrated amp soon. Which cables do I need to connect the two together? Noob question I know but any help is much appreciated!
The back of the Wharfedale's can be seen here at 1:13
And the back of the Rega amp can be seen here at 0:54
http://www.youtube.com/watch?v=UzsCfyI1pJU
Sorry if this is a stupid question but it's my first real hifi setup, thanks in advance =)
toyota man
toyota man's picture
RE: Which cables do I need to connect my speakers to my amp?
Hi you can use two or four core cable  it depends if you want to bi wire or not I am sure some one will know if single or bi wire is best as you can bi wire speakers if you want to
__________________
Dariuz
Dariuz's picture
If possible could you link me an example of what you mean? As you said it would be good to know if it's worth biwiring, thanks for the help =)
toyota man
If you bi wire you will need a four core cable for each speaker at th amp end you will need to connect both blacks together to the - terminal on amp both reds together to the + on the amp at the speaker end you will have to remove the links on the speaker terminals and then connect one black to the tweeter - and one black to - bass/mid  and connect one red + to the + on the tweeter and one red + to mid bass+  be carefull not to short out speaker wires ie do not touch red to black so check no cables ( red/black) touch each other  before switching on your amp I hope this helps
__________________
Dariuz
Dariuz's picture
Okay, great. So to clarify, two cables like this one:
http://www.petertyson.co.uk/ebuttonz/ebz_product_pages/atlas_equator_2.0...
toyota man
Yes looks good to go two banana plugs amp end four  banana plugsspeaker end don't forget to remove links on speakers   beauty, eh beauty, eh happy new year
__________________
Dariuz
Dariuz's picture
Happy new year to you too, cable problem solved =D
MajorFubar
MajorFubar's picture
HOW MUCH??!!  Don't waste your money which could be better spent on something else!
Get yourself on eBay and search for OFC speaker cable.  I use this, and even with this I've seriously over-egged the pudding in terms of how good it needs to be to carry audio to a pair of speakers:
http://www.ebay.co.uk/itm/SPEAKER-CABLE-Transparent-OFC-Wire-40A-Heavy-D...
Or even nip down to Wilkinson's or B&Q and look for something similar.  Just make sure it's OFC and not too thin and straggly.
Really, it's all you need.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
