Upgrade advice
1 reply [Last post]
rich51080
rich51080's picture
Hi everyone.
I am looking to upgrade the below for a one box solution. I am looking at the Primare cd10 as It has great reviews. I have b&w 705 speakers. Would the Primare give a better sound than my current setup. There is no where nearby to demo. Advice sought after. I have heard Primare stuff in general is of excellent sound and quality.
Rotel RCD-02 cd player
Rotel RC-03 PRE AMP
Rotel RB-03 POWER AMP
Andrew Everard
Andrew Everard's picture
Re: Upgrade advice
Not too sure this will be an upgrade - probably more of a sidegrade. The Primare should sound as good as the Rotels, or at least pretty close, and of course has the one-box convenience. But then I guiess the one-box thing is what you're after, so I think you'll be fine.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
