Save money, build your own speakers
42 replies [Last post]
altruistic.lemon
altruistic.lemon's picture
Online
At least, that's what I thought. I'm pretty good with my hands, having knocked the odd book case together, can saw a straight line, so why not? You've got to give it a go, after all. The aim was for bookshelf speakers for the study/bedroom.
Read up a bit, decided on something the small Harbeth size, found it was based on the BBC LS/3a, read up about that, found a suitable (I hope) tweeter and woofer, bought some three ply and off I went. Well, not quite, had to design the crossover, but there's lots of programs for that on the net, so went 2nd order Linkwitz-Riley because they're  a flat frequency response.
The saving money bit is already out the window. The speakers cost £200, the wood £25, the crossover £150, then there's screws, glue, routers, jigsaw, varnish - I'm already up for £500 and have no idea what they'll sound like. The aim is a Harbeth like sound, by the way.
Chose sealed box because it seemed easier than ported. That means precision box building, don't have the proper tools over here so, though the boxes are pretty good, airtight they weren't which meant sealing. It also means that until the last screw is in place I'm not going to know whether I did good or bad. Apparently you can tweak crossovers, but with a sealed and glued box, that's not going to be so easy.
To-night's the night, anyway. Just waiting for the sealant to dry, then I'll do the final bit of soldering and put the baffle in. It's either going to be a "told you so" or champagne.
tyranniux42
tyranniux42's picture
RE: Save money, build your own speakers
Good luck with the venture!
would love to do something like this myself but that would mean having to do away with my 602's which I love and will never get rid of!
Let us know how you get on
__________________
Main System: Naim CD5XS or DAC Magic -> Naim Nait XS -> Naim Ovator S-400
2nd System:  Naim Unitilite -> B&W 602s3
Headphones: Naim CD5XS or DAC Magic -> Graham Slee Solo -> HD650
Home Cinema: Sony KDL 40D3500, Sony BDP s370, Sony DAV-IS50, XBOX 360, PS3 & PC all into DACMagic for passthru or decoding
FennerMachine
FennerMachine's picture
I couldn't be bothered with the time and hassle!
I would much prefer someone else to do the hard work of testing/tweaking to get good sounding components and speakers. The amount of time, research and experience involved...
On the other hand part of the fun in some hobbies such as model planes and train sets is in the making of them and the design you put in yourself.
Hope they sound good, and if not you could reuse the parts, just make a new enclosure.
__________________
CA 751BD , QUAD 44 pre amp, Quad 303, Quad 21L2
Denon AVR-3801, Samsung LE32R87BD 32" TV, Quad L2 Centre, 78DS
FATS 2828
FATS 2828's picture
  Are you well insured ? Smile
__________________
FATS2828
Rob998
Rob998's picture
I must admit, i do quite fancy doing this, building a 3 way speaker but dispensing with the passive crossover & tri-amping with an active crossover in my rack.
The problem is, I would then get carried away & end up with 7 amps, a pre & 6 powers, feeding individual drivers! Jeez, can you imagine the amount of wires!
It's never going to happen if I'm honest with myself, but a nice little thought experiment nontheless!
__________________
Systemdek IIXE900/Roksan Tabriz ZI/AT120E, Marantz CD6004, Sony TCK-661S, Tascam 34B, Arcam 8R/8P, Triangle Titus TZX.
chebby
chebby's picture
I assume you have pulled the original design report from the BBC's R&D archives...
http://downloads.bbc.co.uk/rd/pubs/reports/1976-29.pdf
...I know things have changed a lot (unavailability of the specific KEF B110/T27 variants originally used etc.), but the cabinet dimensions are all there along with crossover diagram and instructions on damping and sealing and materials.
Fascinating reading anyway.
Good luck with them.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Inter_Voice
Inter_Voice's picture
Hope you can suceed and awaiting to hear your outcome.  Twenty years ago I did similar DIY as yours but the result was not satisfactory  Crying
__________________
Enjoying music from a dream hi-fi system in a well treated room.
CnoEvil
CnoEvil's picture
You certainly don't want to end up with a "Lemon". embarassed
Here's hoping....
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
BenLaw
BenLaw's picture
Great stuff, pictures please!  Smile
__________________
HiFi   /   A/V   /   Bedroom
altruistic.lemon
Online
@Chebby, yes, thanks, studied those closely and used their cabinet construction. The crossover couldn't use - made for the Kef drivers that don't exist any more (I substituted SEAS and Monacor) plus was 11/15 ohm so substituted the Linkwitz/Riley.
@cno -  beauty, eh
@ben law will do, but slight complicating factor - the cold has slowed the sealant curing banging head against wall  .
@ everyone else - cheers for the support  Smile
Diamond Joe
Diamond Joe's picture
Oh Lord, the very thought sends a cold chill down my spine - just tidied mine up - not a fan of many/messy wires.
Good luck with your project altruistic.lemon, and I'd like to see some piccies too, cheers. good job Smile
__________________
He's not a diamond geezer, or called Joe!
SteveR750
SteveR750's picture
Even iof they don't work, well done for trying. I thought about a Wharfedale Denton kit years ago, and didn't have the courage as I don't have the patience to make anything other than a nuisance. Finers crossed! Show us some pics by the way, and what drivers did you fit?
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
Dr Lodge
Dr Lodge's picture
An old school mate of mine is now designing and building speakers, presumably the construction is outsourced to a company that has the skills to make these well as I would guess they're a tad more diffcult to make that traditional box speakers!
Curvi Speakers
__________________
HiFi #1: Wadia 861 CD & digital i/o | Transparent Ultra MM Balanced | Muse Electronics Model Three Hundred Monoblocks | Townshend Isolda Biwire | ATC SCM40s | Partington AV Minim with granite shelves | Samsung PS50Q97HD | Humax FOX Sat HDR | Sony BDP-s470 | Cambridge Audio DAB500
HiFi #2 : Squeezebox Touch lossless FLAC | DNM Interconnect | Merdian 206B CD | Cable Talk Broadcast 2s | Denon DRM-600 deck | MF FM1 Tuner | AR EB101 TT w/Roksan Blue | MF P-100 pre | DNM Interconnect | MF X-A200 power | Nordost Flatline triwire | EPOS ES30
abookcase
abookcase's picture
That looks insane! Where do I buy! Cool
__________________
Marantz PM6004
Source: PC/Laptop
Chord Carnival SilverScreen
Chord Crimson Plus Interconnect
Monitor Audio Bronze BX2's
paradiziac
paradiziac's picture
I've seen those speakers somewhere, retail about 4-5K IIRC?
Seems rather expensive since the Jordan full range driver does away with the crossover.
Dr Lodge
Dr Lodge's picture
About £4k I believe. They're Curvi-hifi Model 1 Version 2 speakers. I have no idea how many have been sold, I would have thought quite a low number.
__________________
