Abingdon Music Research announces 'premier class' integrated amplifier
AMR AM-777
Described as a 'Pre-Main Amplifier', the AM-777 combines valve and solid state operation, with 'unconventional valve/bi-polar devices, a dedicated, transparent volume control and thorough power supply sections.' It also has built-in digital-to-analogue conversion, fed from a USB input.
The preamp has four line inputs, one paralleled on XLR connections, a high-precision 71-step volume control and preout sockets, while the power amp combines a valve voltage-gain stage with a solid-state current gain section using bi-polar devices.
The power output is 60W per channel, AMR saying this is stable whether the load being driven is 8 ohms or 4 ohms.
Latest Videos From
Separate transformers are used for the valve and output stages, and the amplifier can be switched to operate as an integrated amp, separate preamp and power amp sections, or as a monobloc power amp.
The AM-777 sells for €2999 excluding VAT, which should equate to around £3175 with UK tax included.
Follow whathifi on Twitter
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
