Flagship 2050i floorstanding speakers join Q Acoustics 2000i series
Now available is the flagship speaker in Q Acoustics' 2000i series, the floorstanding 2050i.
Standing just over a metre tall – 100.6cm, to be precise – the new model is a two-way reflex design with twin mid/bass drivers, and sells at prices from £420/pr, depending on finish.
The speaker has a new 25mm dome tweeter with a multilayered diaphragm material in place of the usual treated fabric or hard dome material, and this is 'super-decoupled' from the speaker's main baffle.
Latest Videos FromWhat Hi-Fi?
Meanwhile the 16.5cm mid/bass units use a new carbon fibre/ceramic coated paper cone in place of the paper/mica mix of the previous model, with Q Acoustics saying this gives lower distortion, a cleaner, more open sound and faster transients.
The company's Tony Jones explains that 'The new 2050i loudspeaker is clearly Q Acoustics' best model so far.
'It boasts ultra low, class leading levels of distortion, a superfast transient response, extended bass and a wonderfully smooth and open treble.
'It’s a speaker that is so good it allows the listener to enjoy the true ‘joie de vivre’ of music.'
The terminal panel for speaker cables is mounted on a recessed plate on the bottom of the cabinets, both tidying things up and enabling the speakers to be used very close to a rear wall if required.
The new speakers have 92dB/W/m sensitivity and 6ohm nominal impedance, and are designed for use with amplifiers of 25-150W.
They cost £420/pr in graphite black/walnut, or £550/pr in piano black or white.
Follow whathifi.com on Twitter
Join whathifi.com on Facebook
Andrew has written about audio and video products for the past 20+ years, and been a consumer journalist for more than 30 years, starting his career on camera magazines. Andrew has contributed to titles including What Hi-Fi?, Gramophone, Jazzwise and Hi-Fi Critic, Hi-Fi News & Record Review and Hi-Fi Choice. I’ve also written for a number of non-specialist and overseas magazines.
