54 posts / 0 new
Last post
gasolin's picture
Last seen: 5 days 13 hours ago
What can we do to avoid listening fattigue?
Listening fattigue is the worst thing and i think it's most the tweeter that courses listening fattigue, some say speakers like B&W 685 & Monitor Audio BX2 although there are good, have listening fattigue, which only can be noticed using a speakers more then up to like 30 min in a store where you often are listening to more then one speakers with in the time you are in the store.
What can we do to avoid listening fattigue? (other then look for new speakers)
Hifi: Marantz PM8005,Marantz CD5005, Rega RP1 Queen Limited Edition, Mission LX-2 on isoacoustics 155 stands, 2x4 meter Supra Classic 6 speaker cable, M2Tech Hiface 2 into TC Electronic BMC-2 and supra digital interconnect
CnoEvil's picture
RE: What can we do to avoid listening fattigue?
- Match kit carefully
- Pay attention to room acoustics
- Fully understand your own taste and spend a lot of time demoing before purchasing.
- Choose well mastered recordings where possible.
- Avoid silver coated cabling unless system is too dull sounding (this is much less important than the above points)
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
steve_1979's picture
Last seen: 6 days 16 hours ago
Warm sounding speakers that have a soft treble sound or have less treble volume are easy to listen to without fatigue. But IMO warm sounding speakers also tend to rob music of some of it's detail and clarity so they can be a trade off.
The best way to have a system that doesn't fatigue is to use speakers and amplifier that keep distortion to a minimum. This way you can still have lots of detail without the sound ever getting tiring. Just have a listen to some neutral sounding studio monitors such as Quested speakers to see what I mean. They have all the detail you could ever want but are also easy to listen to all day long without ever getting fatuging.
Hi-FiOutlaw's picture
Last seen: 1 week 1 hour ago
I had my MA B4 for 10 years and never had listening fattigue, i've MA RS1 for one year and never had listening fattigue, and i've 10 hours sessions.
If you have listenhig fattigue some thing in your system is not made for you!
if you can't spend money in a new set of speakers try to change the speaker cables, 100% copper to smooth things a bit!
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
A 'lively' and reflective room can be sometimes sound fatuging. Try putting carpets/rugs/soft furnishings in front of the reflective surfaces.
simonlewis's picture
Last seen: 5 days 14 hours ago
I avoid listening fatigue regularly by switching the music off & switching the tv on. Smile
Overdose's picture
Last seen: 2 years 1 month ago
In all honesty, it's not something I've ever noticed and I always thought was an audiophile myth.
10 seconds of Emeli Sande though, is enough to make me want to turn the system off, but then that's probably not the same thing,
GMK
GMK's picture
Last seen: 3 years 1 month ago
Amen to that
busb's picture
Last seen: 2 weeks 2 days ago
I do this! It's the only time I turn the volume up at all on my TV at all - I turn it up really LOUD until I can just about hear a broom handle thumping on the floor under my chair. I then know it's time to to switch off the TV & resume listening to my stereo.
On slightly more serious note, this was never a problem until 5 months ago when I bought a new amp. Most of the time, my system sounded amazing but for a small percentage of pop recordings that sounded harsh & often over-compressed. Reducing the speaker's toe-in helped, as did replacing my ancient speaker cable. Since fettling my system, it's now less of an issue but having the best system I've ever owned by some margin, that's very revealing - it's brought home just how poor some recordings are - even a few classical recordings are very indifferent but some pop is appallingly recorded to the point I have trouble working out if its the recording industry being cynical or incompetent.
It's been touched on in this thread but the solution IMO, is not to go for a warm inoffensive sound where every recording in one's collection sounds "acceptable" - as tempting as doing so may seem. It's a tough one though, we want to hear music without wincing but still have some excitement. Careful matching helps & I hope this trend for speakers' specs to be 40 - 40kHz is backfiring on customers!
Mac Mini - USB - M-DAC+ - XLR -  Primare Pre32 - XLR - A34.2 - Quadral Chromium Style  8. CA azur 751BD. oak Podium rack, B&W P5 Wireless, iPhone 6s
CnoEvil's picture
Did you ever connect up your SL6s to your current system?
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
Listening to a live rock concert is the same. Lower the volume.for a while???
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
busb's picture
Nope - but you've reminded me. Going back to the spare bedroom to bring down the 2nd one after typing this...
CnoEvil's picture
Please let me know how it goes......it should be a great match with the Primare, and be almost holograhic on certain types of music. There should be Zero listening fatigue, though at the expense of some excitement. The SL6s crave current the way adrenalin junkies crave danger.
busb's picture
Oops - gone back to using my laptop here instead. Now been on for 15mins. Well, they work fine but any comments I make need to be in the context that they hadn't any current for 18 months so will leave them for as long as I can take them! Started off with a couple of tracks from Lamb's "What Sound". They sound SLUGGISH. Imaging is OK but hell, if the Arros do only one thing absolutely brilliantly, it's imaging & throw in the Primare - height as well. Am listening to the 2nd disc of Mothership that does sound better. especially "Nobody's fault but mine" but hell that sounds good with my head under water!
CnoE, they don't sound awful - just a little syruppy at the mo so yes, they ain't going to sound fatiguing. Let's give them a fighting chance. Bass isn't very well defined...
fr0g's picture
Last seen: 3 months 2 weeks ago
The best way to avoid "listening fattigue" is to use a spell.checker imo. Smile
BenLaw's picture
Last seen: 1 year 11 months ago
Does a spell.checker require a separate punctuation.checker?
I am the danger.
Pages
Log in to post comments
