Cleaning your hifi
6 replies [Last post]
drummerman
drummerman's picture
A couple of things which I found useful to restore things closer to their original state;
http://www.tableauproducts.com/categories/tableau-dry-lube-large/4
This silicon spray is good for metal casings and plastic parts. It easily removes finger marks and returns faded or dirty plastic quickly to a as new state. Better than either furniture polish or window cleaner. Wipes off easily.
http://www.commaoil.co.uk/productsguide/view/6/287
A non-corrosive contact cleaner, safe to use on metal and plastic. Useful to clean speaker and rca sockets, internal components such as scratchy volume pots, copper bars and other internal connections as well as fuses/holders, exposed ends of speaker cables, interconnect and power plugs with their associated fuses.
I have used these two to completely spring clean my hifi inside/out as well as restoring an AV receiver to almost new condition. They are cheaper than many 'made for audiophile' products and most probably just as good.
regards
__________________
Pretty ... and pretty proud of it
chebby
chebby's picture
RE: Cleaning your hifi
These are perfect for keeping the shiny black and 'piano-gloss' stuff dust free...
http://www.scjohnson.co.uk/nqcontent.cfm?a_id=5876
(Use the non 'fragranced' ones.)
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
drummerman
Now I can't edit my post ... ??? - Sure it never used to be that bad (or I am just dimm and do something wrong)
Anyway, the silicon spray is also very good for polyprop cones and vinyl covered speaker cabinets. They look like new after.
Yep, feather dusters are very useful. I know everything about them ...
regards
__________________
chebby
chebby's picture
You can only edit until someone has replied to it.
__________________
Paul.
Paul.'s picture
I use a rocket blower on my speaker cones to keep them dust free.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
drummerman
Thanks chebby.
Just wanted to add the silicon spray also works well on older, faded polyprop speaker cones and vinyl covered speaker cabinets.
regards
__________________
plastic penguin
plastic penguin's picture
For some reason I can edit my posts before and aft... very puzzling http://www.whathifi.com/forum/digital-and-analogue-radio/any-recommendations-for
Anyway, back on topic. I use a dry duster for the top of the amp and damp cloth for the speakers, unless someone (of the smaller equation) has put mucky chocolate finger marks over it, then I'll use furniture polish (sparingly).
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
