22 posts / 0 new
Last post
admin's picture
Last seen: 1 day 18 hours ago
Monitor Audio RX6, RX Centre, RXFX, RXW12. What amp?
Hi
Following the reviews from What HiFi and lots of demos at the likes of Superfi and Sevenoaks I have decided to purchase the RX6, RX Centre, RXFX and RXW12. The system sounded amazing in the demo room with a top of the range amp. I currently have an Onkyo TX-NR609 amp.
Would you advise me buying a better amp and if so which one would you recommend? Thanks
Anonymous's picture
RE: Monitor Audio RX6, RX Centre, RXFX, RXW12. What amp?
If it helps I listen to music and watch movies about 50/50. Thanks.
davidf's picture
Online
Last seen: 11 hours 30 min ago
Do you like things nice and exciting, or more laid back and easy going?
the little audio company, jewellery quarter, brum
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
Anonymous's picture
Both kind of. When I'm watching films nice and exciting and whilst listening to music a bit laid back. Thanks.
Anonymous's picture
davidf's picture
Online
Tricky. Pioneer and Yamaha are the two extremes, so look at Marantz or Denon.
Anonymous's picture
Thanks David. I pick my speakers up at the end of the month so might see if I can demo a Marantz and Denon.
MUSICRAFT's picture
Last seen: 18 hours 1 min ago
Hi Scoterz147
Welcome to the WHF Forum Smile
Your budget for an AV amplifier is?
In the meantime and fwiw, Monitor Audio speakers pair superbly with Yamaha AV amplification  :star:
Btw, Anthem AV amplification is also worth bearing in mind as i've found their MRX 300 and MRX 700 amplifiers to also work a treat with the Silver RX6 AV12 speaker package :rockout:
Out of interest what finish have chosen for your speakers please?
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi, AV & Multimedia dealer
Anonymous's picture
Thanks for your help Rick. I'm a bit of a novice with this kind of thing and everything I've learned has been from sites like this.
I was going for the black gloss finish but eventually decided on walnut. They look really nice in the flesh and the money I saved (£400) I've put towards speaker wire and jumpers.
My budget is about £1200. Thanks.
MUSICRAFT's picture
Hi Scoter147
Thanks for your reply.
Nice one. Silver RX6 AV12 speakers also look great in walnut finish  Dirol
With Yamaha's current Aventage 10 Series on its way out then you should be able to find the excellent Aventage RX-A3010 AV receiver within your budget. Alternatively Anthem's MRX 300 AV receiver is also worth a look Smile
Btw, if you haven't already picked up accessories then i'll recommend using the links supplied with the speakers and for speaker cables also consider using standard 79 strand OFC or at a push 500 strand OFC. I feel these speaker cables will be more then good enough for your speakers and ones which should also cost very little money. Fwiw, i use standard 79 & 500 strand OFC speaker cables with speakers & electronics such as Monitor Audio's Platinum PL300AV, Chord Electronics DSP8000/Plinius Odean, etc.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi, AV Dealer
My system - Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
Anonymous's picture
Hi Rick
Thanks for the advice. You could write all I know about speaker cables on a stamp! I'll be getting the 500 strand if I can afford it. If they're good enough for the PL300 they're good enough for me. How much would I be looking to pay per metre for them?
Thanks again.
MUSICRAFT's picture
Hi Scoterz147
Your welcome.
Yes, these standard speaker cables are also good enough for speakers and electronics such as PL300AV, Chord Electronics SPM3005, Anthem MRX 700, etc. Save your time and your money. Anyway, you should be able to pick up these standard speaker cables from places such as local electrical stores for little £/m.
All the best
Rick @ Musicraft
Anonymous's picture
Hi Rick
Thanks again for the info. Think I'll be going for the 500 strand. I pick up everything 2 weeks today. Can't wait. Thanks.
James
MUSICRAFT's picture
Hi James
Your welcome Smile
All the best
Rick @ Musicraft
davidf's picture
Online
You don't need to know anything about cables to know what you like the sound of. I'd recommend trying two different cables to see if you hear a beneficial difference. If not, go for the cheapest. If you can hear a difference, it might be worth trying a few more.
Anonymous's picture
Hi David
Thanks for the info. I'm picking everything up a week on Friday and haven't got time to test the cables whilst I'm there. I also need to tell them what cables I'm choosing soon as they said they would terminate the ends for me ready for when I pick everything up.
I'm prepared to spend £15/m. Thanks.
James
Pages
Log in to post comments
