Russ Andrews introduces SuperKord Reference and Signature mains cables
Russ Andrews SuperKord Reference-SD II
The SuperKord Reference-SD II and SuperKord Signature-SD II both use improved Sawyers Disc technology to enhance the RFI (radio frequency interference) reducing properties of the woven cable. Less RFI means the user benefits from more information being revealed on CDs, DVDs and Blu-rays, claims the company.
It's a new method of terminating each conductor at the plugs, using a series of perforated discs, said to give "smoother and more even [interference] rejection across a wider range of frequencies, which is also many times deeper and clearly measurable'.
Article continues below
Russ Andrews says the Reference-SD II and Signature-SD II use Kimber Kable's woven cable technology, with 16 hyper-pure copper conductors in the Reference model and 24 conductors in the Signature product.
They also benefit from a new proprietary earth enhancement, helping to attenuate earth wire RFI.
You can buy the SuperKord Reference-SD II for £950 (1m) and the SuperKord Sgnature-SD II for £1250 (1m).
Follow whathifi.com on Twitter
Join whathifi.com on Facebook
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
