Goodmans, Grundig and Bush Freesat HD boxes get BBC iPlayer upgrade
Grundig GUFSAT01HD
Most of the boxes will be upgraded via an "over-the-air" download.
All customers have to do is connect the box to a broadband internet service with a minimum 1Mb speed and they'll find a link to the iPlayer service when accessing the menu via the red button on any BBC service.
However, Harvard International – which manufactures the Bush, Goodmans and Grundig boxes – says a number of early models are not capable of receiving the upgrade. It's offering those customers a replacement Freesat HD set-top box for a small charge.
After the over-the-air download, those boxes that need relacing will display an on-screen message asking customers to contact the Harvard support centre on 0871 230 4695, where they can register their details for a replacement box.
The new boxes will be delivered to owners, for which there will be a charge of £14.99 to cover the cost of the courier service. Existing set-top boxes will need to be returned for recycling as part of the process.
The following products will receive the upgrade:
Bush BFSAT01HD
Goodmans GFSAT200HD
Goodmans GFSDTR500HD
Grundig GUFSAT01HD
Grundig GUFSDTR500HD
Customers can check if their set-top box has been upgraded by checking it has the new software, version 2.0.1, via the 'Settings' function in the menu (shortcut Menu 0, then select 'Network settings').
Follow whathifi.com on Twitter
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
