Speaker height question
3 replies [Last post]
paulsue38
paulsue38's picture
I am about to order some Dynaudio Excite 12 speakers. I am aware that the norm for stands is 60cms. However, the way the room is set up 50cms is more practical giving an overall height of 785cms.Some seem to suggest that this is too low.
Despite this compact floorstanders seem to be able to cope with the tweeter being lower.
For instance the Spendor A3 is only 750 high and the Neat Motive SE2 760 high? The Dynaudios will be higher than both!
Am I missing something ,if its ok for floorstanders then surely the bookshelf speakers can be at this height?
Any advice would be gratefully received.
Best wishes
Paul
__________________
Roksan Caspian Tuner, Roksan Kandy L111, Cambridge Audio 650, Spendor A3
Ian64od
Ian64od's picture
RE: Speaker height question
Hi
If the tweeter is at ear level when you are sitting in your normal listening position this should be fine.
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
SEE Revolver TT/CA 540/Ortofon 2M Red.
shafesk
shafesk's picture
I wouldn't worry about that difference, you can always tilt your speakers down using the supplied spikes at an angle so the tweeters are pointing at your listening height. I think you are also forgetting to take in your height into consideration, your listening position is higher the taller you are for instance. I wouldn't worry too much about the Excites to be honest, I've demoed them sitting below tweeter height and I couldn't hear a difference standing up to ear height. These Dyns have an immersive soundstage wherever you sit.
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
paulsue38
paulsue38's picture
Thanks for the advice. I will probably stick with 50 cms. I did notice when browsing on the Spendor website that they specify a height range for their bookshelf speakers of between 50 - 65 cms. I am also only 5ft 7 ins! (as my kids keep reminding me)
Paul
__________________
