Roksan K2, Caspian M2 or something else?
16 replies [Last post]
newbie80
newbie80's picture
__________________
CnoEvil
CnoEvil's picture
RE: Roksan K2, Caspian M2 something else?
Hi there and welcome to the forum.
IMO. You are asking the wrong question - You should be asking "What should I have on my demo list, as well as the Caspion".
Examples might be
- Sugden Mystro / A21
- Musical Fidelity M3i
- Leema Pulse 111
- Electrocompaniet PI-1 / ECI-3
- Densen B110
- Bel Canto C5i
I strongly suggest you hear as many possibilites as you can....BTW. What is the rest of your system?
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
plastic penguin
plastic penguin's picture
@ the OP: Please repost
@ the OP: Please repost stating the rest of your kit and budget.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
newbie80
newbie80's picture
Thanks for the input
I have already auditioned the MF M3i and it sounded a bit dry to me, not as musical or warm as the K2.  Maybe it is my ears but it did not get my as excited as what I have, I could be wrong as that was my impression after spending about 2 hours with it
I will look into some of your other suggestions also
Any other suggestions?
__________________
newbie80
newbie80's picture
Sorry must be the connection or something as I have sent 3 times but here it is again
Speakers are being upgraded to either monitor audio RX2 or GX100
Source is Oppo 105, DAC MF DAC1
Room is on the small size 3m x 3m and speakers are on stands about 25 cm from rear wall
Hope that the above is of some help
__________________
CnoEvil
CnoEvil's picture
It is only your ears that matter.....but remember that there must (imo) be an amp / speaker synergy....and the right pairing can be more than the sum of its parts.
What other speakers have you listened to?
__________________
plastic penguin
Roksan K2, Caspian...
If you go GX100 route, consider Cyrus 8XP. I'm not a big Cyrus fan but the combo worked well to my ears. Try and search out Creek Evo2 which is a fabulous amp for the money and some... otherwise Cno's suggestions seem good.
__________________
CnoEvil
CnoEvil's picture
RE: Roksan K2, Caspian...
The Creek models should have been on the list.
__________________
newbie80
newbie80's picture
I have listened to the PMC bookshelf series Db1i, TB2i, and the new 21, Kef R100, Dynaudio DCM 2/7...I wanted to listen to the Focus series but they were not in stock nor was the excite X12.  The Dynaudio's would need to be placed farther from the rear wall.  Also listened to the Spendor S2, but the one I enjoyed the best was the ProAc D18 but it is to much money for me....lol
I really was not planning on replacing the K2 amp unless it is with something in the same price range.  If I step up to the Roksan M2 that will impact on my speaker budget
__________________
CnoEvil
CnoEvil's picture
You have covered a good range of speakers....if you enjoyed the D18s, how about some of the smaller Proacs. Two other brands that are worth keeping in mind are Epos and Vienna Acoustics.
__________________
newbie80
newbie80's picture
I had listened to the Studio series it was the 110 and 115 i think but they did not hit me the way that the D18 did.  As I said earlier my ears liked it but by wallet is not big enough
Reality is I just want to enjoy the music and the RX2's seemed good enough and the GX 100 was even better but dont really want to spend more than that.
I am happy with the K2 and if I sell it my preference is not to go over the 1000 mark
__________________
CnoEvil
CnoEvil's picture
That's fair enough, but hard to tell from your thread title...as the Caspian is knocking on the door of £1700.
__________________
plastic penguin
Think the GX100 are a speaker that'll match well with most of the aforementioned amps. Only a dem - preferably a home audition - will tell you if the MAs are for your ears or not.
__________________
drummerman
drummerman's picture
Speaker violence. Big problem around here ...
regards
__________________
Pretty ... and pretty proud of it
ISAC69
ISAC69's picture
Hi
I think you should stay with the K2 it is a very good amp and a great value for money too till you can afford a serious upgrade .
  So if you can not afford it now stick with the K2 ( I perssonaly don't like the Caspian
it has a detailed sound and a very good sound stage but I think it has an artifical and too smooth sound for my taste while the cheaper K2 has a worm
and very good neutral sound ) .
__________________
Hi Fi : ROKSAN KANDY K2 - PROAC STUDIO 140 MK2  - ROTEL RCD1520 -  interconnects : Tellurium Q Black - Chord Chorus2
AV : YAMAHA RXV767 - WHARFEDALE 9.CM [C] / 10.2 [SR] / INFINITY PRIMUS PS8 [SUB]
therecruiter
therecruiter's picture
RE: Roksan K2, Caspian M2 or something else?
The Kandy K2 is a great amp and would work well with the MA GX100's or RX2's (of which I have & when demo'd with the K2 amp and Rega ApolloR CDP it was a fantastic combo) but as Penguin stated; the Cyrus 8 range also works REALLY well with the MA RX speakers and IMO the GX50's (which I heard briefly but had to ask what the combo was as it sounded so clear & precise but with fantastic deep/punchy bass and a midrange to die for)!
The Arcam FMJ A38 would be an amp well worth considering as would a 2nd hand FMJ A32 (one on eBay currently) but it depends on what you feel youre not getting from the K2! The Arcam amps are a little warmer but with smoother/tauter bass IMO but not as open/bright at the top end and again fantastic midrange!
I havent heard much from the Roksan range bar the LIII and K2 amps but the Caspian range does get rave reviews!
What about Leema or Creek; even possibly Naim?
__________________
Living room: iTunes to ATV 2 (via AirPlay) to Cyrus 8 DAC with KEF LS50 speakers - Tellurium Q Blue cables
Spare room: Marantz CR603, AirPlay, Monitor Audio RX2's - Chord Odyssey 2 cables
