headphone jack adaptor
16 replies [Last post]
cinemafan
cinemafan's picture
hi - need a 3.5mm to 6.35mm jack plug audio stereo adaptor to use my new headphones with my existing amp/cd player and i was wondering if they are all the same or or some better than others ie gold plated etc? thanks ...
dalethorn
dalethorn's picture
RE: headphone jack adaptor
They certainly are not all the same. I don't think the gold plating matters as long as the adaptor is good quality. I would advise against an adaptor with a recess where the miniplug goes in, especially the screw-on types that some companies issue. Get an adaptor that's flat on that end with just the hole for the miniplug. I have so many of these I just store them in a box, but if I had to buy one I would expect to pay £5 at least and get a good one.
__________________
SoundMagic HP200, Final Audio FI-BA-SS, V-Moda M100, Sennheiser IE800, Beyer DT770LE, FiiO E07K/MicroStreamer/Vamp Verza DAC/amps, FiiO E12/Zen Head amps.
cinemafan
cinemafan's picture
thanks for your reply dalethorn. cos i'm a bit of a thickie, could you link me to the preferred variety of adaptor so I can see what you mean by recess etc. thanks
proffski
proffski's picture
Adaptor Headphone
Try Amazon here:  http://tinyurl.com/azxew8h
Or Canford: http://tinyurl.com/b8lwxah
MajorFubar
MajorFubar's picture
I'm surprised there aren't 'audiophile' adaptors costing £30+ with some loon somewhere swearing they can tell the difference.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
dalethorn
dalethorn's picture
That first link to Amazon with the £3.50 adapter looks right. Although I think the adapters are too short to introduce enough capacitance etc. to modify the sound, I have had a couple screw-on adapters supplied by Beyerdynamic and others which had loose connectivity when screwed down tight onto the 3.5 mm plugs.
__________________
Superaintit
Superaintit's picture
That's the one I chose some time ago. It just does what it's supposed to. Haven't used it that many times, but seems durable enough for daily use.
cinemafan
cinemafan's picture
Thanks for all your replies. I've ordered one in the first link plus a cheaper gold 'professional' one as well, just for comparison.
quadpatch
quadpatch's picture
I agree with Daelthorn, although I will add that if your cable has 'Apple controls' you might get issues with the channels not meeting the connectors properly. The V-Moda and default Sennheiser Momentum cables are like this. Their 3.5mm mini jack has 3 connectors rather than 2 and these require a special adaptor. The ones supplied work of course but replacing them could be a pain.
__________________
PC>JRiver> DAC/amps: FiioAudinstYulongArcamFostex, Audiolab, SchiitOppoIfi ●
Headphones: D7000Q701M80M100, DT770, DT880HP100HP200Mad Dog, HD650 ●
drummerman
drummerman's picture
I would have thought that the 'perfect' adapter is either silver/rhodium plated for better conductivity or at least be pure copper.
I had a quick look on Furutechs site, purveyors of all fancy connectors and couldnt find a headphone adapter which is a surprise considering their ADL line makes h/p amplifiers.
regards
__________________
Pretty ... and pretty proud of it
ID.
ID.'s picture
regards
Reading your post I felt sure that Oyaide must have a silver/rhodium plated one, seeing as I use Oyaide's silver/rhodium plated banana plugs, but they don't seem to make adaptors, which seems strange to me. That said, I've only ever used the adaptors that come with my headphones.
__________________
Observe the signature in its natural habitat.
OneBoxSystem
OneBoxSystem's picture
http://www.aloaudio.com/alo-audio-lariat-1-4-female-to-male-mini-adapter
There you go....
jjbomber
jjbomber's picture
Or, even better, throw the headphones away and spend £1,300 on some active speakers!!!
ID.
ID.'s picture
A little uncomfortable strapped to either side of one's head...
__________________
pauln
pauln's picture
RE: headphone jack adaptor RE: headphone jack adaptor
Because obviously active speakers and headphones have exactly the same function...
__________________
MajorFubar
There you go....
Wow yet another product that relies on the hope that there really is one born every minute. ohhh sure My suggestion of £30+ just wasn't thinking big enough was it. $220 for a 1/4" to 1/8" adaptor? Yeah I'm made of tricks like that lol.
__________________
