PMC OB1
4 replies [Last post]
IanS1
IanS1's picture
Hi, I'm currently auditioning the PMC FB1+ but find them to be a little bass lite with my all CYRUS 8 system, the mid/treble range is just what I need, nice and clear but sweet. Are the OB1's any better for bass depth/extension? I don't think the cables are a problem but I'm using all Chord cables, Chorus interconnect CD-Amp Chameleon Silver Plus interconnect Amp-power amp, Rumor bi-wire. The FB1+ are bi-amped, power amp to the bass units. Any advice much appreciated. Ian ps. Why doesn't this text editor recognise my text formatting, particularly paragraphs!!!!!!!!
__________________
Digital Sources: Mac Mini + ZP80 + Audio Aero Capitole Reference CDPAnalog Source: Nu Magrotor TT + SME V + Cadenza Black + TEAD Groove+SRXAmps: TEAD Vibe Pre/Pulse Power Supply >> Linear B Mono's Speakers: Audio Physic Scorpio II's
Andrew Everard
Andrew Everard's picture
Online
Re: PMC OB1
Yes, the OB1s do have better bass than the FB1+ speakers, but IMHO I've always found the Cyrus amps a bit bass-light with PMC speakers - and believe me, I've used PMCs for a very long time: see current kit list here. That's a personal rather than magazine opinion, of course...
Re the text editor, not sure - try putting < p > (but without the spaces) tags where you want a paragraph break. Seems to work for me...
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Clare Newsome
Clare Newsome's picture
Re: PMC OB1
hi Ian,
Have you considered adding a PSX-R power supply (one or several....) to your Cyrus system? Makes a big difference, and could give you the extra grunt you're after. Try a demo if you haven't already taken the power plunge....
__________________
Group PR Manager - Computers Unlimited;
Former Group Editor of What Hi-Fi? Sound and Vision and Whathifi.com
Twitter: @ClareNewsome
IanS1
IanS1's picture
Re: PMC OB1
Hi Clare,
Yes, I've already got 2 x PSX-R, 1 on the amp the other on the power amp. I think the problem might be that I'm used to the Monitor Audio Silver 8i and to be honest the FB1+ aren't really that bad, just a little more bass would be nice. The bass does seem to kick in more as I turn the volume up, but I don't think my neighbours will stand that for long.
Ian
__________________
IanS1
IanS1's picture
Re: PMC OB1
Hi Andrew,
Thank's for your input once again. I may have to make a tough decision between the FB1+ or the ProAc Studio 140's as the OB1s are little more than I'd planned to spend. I might try the ProAc D15 to see if they're any better.
Thanks for the tip with HTML formatting.
As you can see it works
Ian
__________________
