Solder or screw?
7 replies [Last post]
marafunman
marafunman's picture
Recently change my speaker cable (Chord) and question whether there is any audible difference between connect via banana plugs with just the screw fitting- or whether I should solder.???
Is there any appreciative difference doing the latter
__________________
Paul.
Paul.'s picture
RE: Solder or screw?
Less chance of oxidisation of the exposed material in theory with solder.  Mine is screwed, more through laziness than anything.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
Alears
Alears's picture
No difference sonically. Just the knowledge that a decent solder job will be longer lasting, and you will be a bit stuck if you change cables again and want to re-use the plugs!
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 dac/Tom Evans Groove Anniversary phono amp/Tom Evans Vibe preamp/Linear A power amp/Acoustic Zen Adagios/Chord cables/Oppo 105EU.
chebby
chebby's picture
Online
Solder.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Apple iPad Mini • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
shafesk
shafesk's picture
I screw but only because I don't want to solder my cables. Mind you, my cables do oxidise after a few months so I have to trim them a little bit. If you can't live with that then bring on the soldering iron!  party time!
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
Sospri
Sospri's picture
Online
Both, screw and solder, sorted....
__________________
Logitech Touch > digital input > Naim Supernait >Chord Silverscreen >Spendor SA1s.
Naim Stageline > Inspired Rega P7 Rega Exact.
 Beyerdynamic DT 880 Pro
idc
idc's picture
Screw is fine for domestic application swehere the cables will not be moved about. Solder is best for pro audio, especially where the cable will be moved regularly.
__________________
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
Dr Lodge
Dr Lodge's picture
+1 on that. If you can do both, why not.
AFAIK, pretty much all internal wiring is soldered, therefore I don't see why speaker cable connections should be any different - where practical.
__________________
HiFi #1: Wadia 861 CD & digital i/o | Transparent Ultra MM Balanced | Muse Electronics Model Three Hundred Monoblocks | Townshend Isolda Biwire | ATC SCM40s | Partington AV Minim with granite shelves | Samsung PS50Q97HD | Humax FOX Sat HDR | Sony BDP-s470 | Cambridge Audio DAB500
HiFi #2 : Squeezebox Touch lossless FLAC | DNM Interconnect | Merdian 206B CD | Cable Talk Broadcast 2s | Denon DRM-600 deck | MF FM1 Tuner | AR EB101 TT w/Roksan Blue | MF P-100 pre | DNM Interconnect | MF X-A200 power | Nordost Flatline triwire | EPOS ES30
