New System Help
41 replies [Last post]
SusanB
SusanB's picture
I would like a high class, good sounding and looking unobstusive  and simple to use sytem which supports recording my cds on a hard drive and then ideally playing locally -  streaming stuff all seems a little bit scary. Also, as I live in the Scottish Borders  with slow broadband not sure if this would even be viable.
What I'm considering is the following:  Meridian Core 200 and DSP3200 and an Olive 4HD. Any better suggestions? My tastes in music are 50s and 60s blues and rock'n'roll.
Many thanks
SusanB
SusanB's picture
RE: New System Help
Anyone who can help a young maiden in distress???? Please....
jjbomber
jjbomber's picture
RE: New System Help
Naim HDX for the Olive 4HD would be the main alternative.  That has a 2TB Hard Drive, so should be enough. It may be a case then of Naim amps and suitable speakers. As always, what is best for you may not be best for others, so it's your call. I'm sure that dealers will be accomodating at that price, so arrange a few demos.
omnibeard
omnibeard's picture
RE: New System Help
Do you already own a computer/laptop?
What's your budget - your suggestions are very expensive, you can put a system together to do what you want it to do for a whole load less money.
If you're interested in keeping box count down something like the following would be a very very good set up at a considerably lower price.
NAS drive, try something like Synology DS212J with 2 * 2TB hard drives - should cost less than £350
AVI ADM9 RS active speakers - £1250
Airport Express or Squeezebox Touch - £80 - £180
If you don't have a computer/laptop then this would give you plenty of budget for a laptop (to do the ripping) and/or an ipad/tablet to use as the controller. If you're desperate to spend more money, you could look at the AVI ADM40 instead of the ADM9.
jjbomber
jjbomber's picture
RE: New System Help
She's not looking for a PC hard drive system but a high quality stand alone system, hence the Olive 4HD. She said she didn't want a NAS system due to the slow system. She didn't want to spend less money but wanted high quality. But you knew that right?
omnibeard
omnibeard's picture
RE: New System Help
Oh OK, you're trying to be clever!
So, where does she say she doesn't want a NAS? Where does she mention a slow system?
She mentions slow broadband, but that wouldn't have any effect on a LAN.
But you knew that, right?
She may not want a NAS, but certainly hasn't said so as yet.
S.Coates
S.Coates's picture
RE: New System Help
Susan,
Guessing you've spent some time looking around as the Olive and particularly the Meridian combination isn't something you'd happen to bump into by chance!  Also living in Scotland, and having lived in the Borders, I would really keep away from streaming and a NAS until the broadband experience improves, so yes, the local hard disk system is a great solution. Unfortunately, not many traditional hi-fi manufactures offer such a component but there are media server alternatives, including the Olive, QAT etc.
The primary options are as follows:
1. Your suggested system, although I personally would have doubts over the Ollve 4HD although I assume you'd use the  Meridian DACs. so much less of an issue.
2. Olive does make a so-called 'audiophime model - the 6HD but this is has some strange operation foibles ie the display is at the top of the unit so can't be used in a rack but I'm guessing that's not an issue for you. However, for the same price as that, you could go for the Meriidan Sooloos Control 15, which although expensive at £4750, I'm sure you could get a good deal on the all Meridian system and it is infinitely better than the Olive, also, it has the best interface of any audio product in the world. It does support streaming in addition to ripping, so is future proof if you move or the broadband gets more stable and faster.
3. Although not to everyone's taste looks and sound wise, (but would suit your music tastes, speaking as a huge Elvis  and Sun fan myself!), you could look at Naim. The Unitiserve is exactly what you're looking for as a superb ripper - it really makes outstanding recordings. You could team this with the Unitiqute (combined amp, DAC and streamer) or the new UnitiLite (similar but adds a cd player) or other Naim 'all in ones' or separate amps and DAC.  In the future, the Qute could be a second system in another room streaming from the Unitiserve. Add speakers from Neat (although, not exactly great looking) Amphion,  or B&W 'CM' series or Kef 'R' (all of which do look great!).
4. Another (much cheaper) option is to use something like a Mac Mini, buying a Meridan CD Player if you still would like that option, however, the Mac Mini would again assume absolute sound quality for your money  isn't the uttermost concern, although I'm sure there wouldn't be a great deal of difference between that and the Olive 4HD and most things sound great connected to Meridian!
5. Given your requirements, you could look at Sonneteer, notably the Morpheus Music Centre and matching media server.  Although priced individually at £2500 each,  I'm sure you could get a pretty good package price as I wouldn't think they sell too many!  Although lifestyle oriented, they are 'proper' high end hifi and sound great - theyr're hand made in a wide choice of colours. Just add some speakers such as Amphion.
6. There is also the option of using Olive 4HD or 6HD will an amplifier and passive speakers which opens up lots of possibilities. However, if you want to go down the active speaker route, certainly Meridian is the best (if a very expensive) solution - the Core 200 will provide you with all kinds of sophisitcated technology to tailor the sound based upon your room and how you use the DSP3200s. Certainly, I would strong recommend the Meridian combination over AVI, but then I get the feeling one look at the AVis will be enough to put you off!
If you can get to Level in Fife, give Audio Emotion a call - the best hi-fi shop in Scotland, if not the UK. They won't stock Sonneteer or Meridian but will be a great place for some advice and as a starting point, stocking many brands you can't find anywhere else. Enjoy and good luck!
omnibeard
omnibeard's picture
RE: New System Help
Sorry, am I missing something? What does broadband speed have to do with a NAS (on a LAN or otherwise)?
S.Coates
S.Coates's picture
RE: New System Help
The primary issue is of stability - I know from experience that broadband in the Borders is not reliable with frequent drops. Frankly, calling it broadband is a bit of a liberty...
Have no idea what you don't like or understand about my comments re Meridian.
omnibeard
omnibeard's picture
RE: New System Help
Streaming music from a NAS has nothing to do with broadband. Broadband speed/dropouts have no effect on your LAN or WAN. It is not relevant.
Just seems like quite a claim that Meridian is certainly the best way to go in terms of active speakers. But then you've made a couple of fairly bold absolute claims in your post.
Seems like Susan is just getting advice to go and spend a fortune. If she wants to just spend a fortune then fair enough, but what she is asking to achieve can be done for a fraction of the cost that the equipment suggested so far will cost.
CnoEvil
CnoEvil's picture
Online
RE: New System Help
Hi Susan, you might also like to check out the Linn DS/DSM.
Here is a map of the dealer network: http://www.linn.co.uk/buying/findashop
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
michael hoy
michael hoy's picture
RE: New System Help
But this has nothing to do with broadband, it would be an internal network (Wireless or wired), the only need for a broadband connection would be for downloading music from the internet.
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
omnibeard
omnibeard's picture
RE: New System Help
Phew - thanks Michael, wasn't sure if I was going mad there or not!!!
moon
moon's picture
RE: New System Help
what do you mean going? Wink
__________________
jjbomber
jjbomber's picture
RE: New System Help
''streamong stuff seems to be a bit scary'' wpuld suggest she does not want a NAS.
It's a case of what Susan wants and asks for, not what you want. You're not a politician; so answer the question.
moon
moon's picture
RE: New System Help
one iMac connected by an optical cable to these ADM40's
http://www.avihifi.co.uk/
__________________
