Headphone amp
3 replies [Last post]
Macspur
Macspur's picture
Santa very kindly brought me some Grado S60I headphones, now all I need now is a dedicated amp to do them justice.
Nice though it would be, don't really want to spend silly money on a Sugden... would appreciate any suggestions.
The ones I've briefly looked at are Graham Slee Novo and the Lehmann Rhinelander.
The other thing is, I have no experience with these pieces of kit and have no idea how to integrate it into my existing system, so any pointers would also be much appreciated.
Mac
__________________
Accuphase E350 amp, Electrocompaniet EMC1UP CDP, Siltech 25th Classic anniversary 330I  XLR Harbeth Super HL5 on Sound Anchor Quod ELS63 stands, Chord Odessey2 speaker cable.  Grado SR60 headphones.
shafesk
shafesk's picture
RE: Headphone amp
Hi Mac, I own a Grado sr60i too. I've also heard the Slee Novo with an AKG K702, it has adequate gain to drive those and should be no problem for your Grados. It sounds very neutral and will let you hear your Grados the way they were meant to be heard. I'm just a bit concerned about the treble, do you think that you need an amp to tone it down a notch? The Slee might just increase it by a degree but I suppose if you are using your cdp as the source then it should be fine.
Regards,
Shafin
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
ifor
ifor's picture
RE: Headphone amp
Mac
If you jump to the Graham Slee website and join the owners club forum you can arrange a 2 week home loan of the Novo and get useful advice from current owners.
__________________
Source 1) "Inspired" Manticore Mantra turntable c/w Rega RB 301 arm, Goldring 1042 MM Cartridge, Graham Slee Reflex M phono stage, Graham Slee CuSat 50 interconnect
Source 2) Cyrus CD8 SE CD player
Source 3) iTunes (ALAC), iMac, Devolo Homeplugs, Apple TV3, Toslink, Arcam rDAC
Source 4) Technics SL-7 linear tracking turntable.
Roksan Kandy L3 amp, Spendor A5 speakers.
Other rooms: more Airport Expresses and Homeplugs with Denon AV system and Denon Mini system.
Macspur
Macspur's picture
RE: Headphone amp
Thanks for the replies... yes I thought the treble a touch on the bright side, but not painfully so, overall very pleased with the Grados.
I will check out the Graham Slee website.
Mac
__________________
