UPDATE: Order your replacement Cambridge Audio DacMagic power supply online
All owners of the Cambridge Audio DacMagic will get a replacement power supply free of charge following problems with the casework
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
You are now subscribed
Your newsletter sign-up was successful
Alternatively they can visit www.cambridgeaudio.com/dmpsu where they can order a free PSU replacement.
STORY POSTED 30/09/09:
Cambridge Audio has decided to replace the power supply unit (PSU) on all DacMagics sold in the UK. The move follows reports on our Forums of the PSU casework sometimes coming lose or cracking.
"We have recently been alerted to a problem of cracks appearing in the casework of some DacMagic power supplies after a period of sustained use," says CA.
"We believe this only affects a small number of UK PSUs, however Cambridge Audio has taken the decision, as a precautionary measure, to replace all UK DacMagic power supplies."
Owners will be contacted in the next week using the details given at the point of purchase and a replacement PSU will be provided free of charge. This will take a few weeks.
In the meantime, you should check your current PSU for any cracks or signs of damage. If the casework is damaged in any way, switch off the mains at the wall socket, unplug the PSU and do not use it again.
CA says this problem only affects UK power supplies, and not those sold in other European countries, Australia or North America.
If you do not hear from Cambridge Audio by November 15th 2009, you can contact the manufacturer directly using the online form available on the company's website.
You can read the full statement from Cambridge Audio here.
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
