Very slow internet after installing NAS?
27 replies [Last post]
canada16
canada16's picture
Hey
I installed a Gigabit switch yesterday and put all 8 ethernet cables on that, but I then put a NAS on.
Now when I click on the internet, it takes ages and ages, and sometimes times out on the net.
I have internet because all the lights are good.
Its got to be the NAS, Any Ideas? this is sorta my first NAS and have no idea what all the settings are in the menu's.
Looked online and cant see anything.
__________________
Living room: Monitor Audio RX6-Centre -RXFX-
SVS PC13-ULTRA-WOW!!!!! Surprised
Onkyo TX-NR818, Panasonic 50G20, PS3, Sony BDP-370 - Macbook Pro i5 For HTPC.
BEDROOM- LG 32LE4900 Pioneer VSX-921 MA- R90HD & 225HD, RSW12
Rocky Mountain Vertex Mountain bike.
scene
scene's picture
Re: Very slow internet after installing NAS?
Just to confirm things: if you disconnect the NAS from the switch - does the internet speed up? Only ask as you said you also installed the switch yesterday, so just wanted to confirm everything is working with just the new switch.
Oh yes, what make of switch and NAS?
If your internet is still slow without the NAS, pull everything out of the switch apart from the PC and internet modem/router and see what things are like then.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
canada16
canada16's picture
DUH!!!
Never thought of that, will take the NAS out and see what happens.
Its a D-LINK DNS-320.
It was working fine though before I installed the NAS, as I installed the switch first and all was good.
It seemed to have slowed down after I installed the NAS software.
Nice 1
__________________
scene
scene's picture
canada16:
DUH!!!
Don't worry - sometimes it just helps to have someone else look at a problem...
Nice 1
What "NAS software" - was this something installed on the PC - the D-Link "Easy Search" utility maybe?
__________________
canada16
canada16's picture
Hey it was the software provided by the NAS it was on a disk, it ran through the setup. and I justkept pressing next as had no idea what half the stuff meant.LOL
__________________
scene
scene's picture
canada16:
Smile That's how I felt when I first installed my ReadyNAS...
I ended up disabling 95% of the software running on the NAS. Still need to disable some of the stuff on the PC I installed it on, as most of it unnecessary (with my NAS).
__________________
Ravey Gravey Davy
Ravey Gravey Davy's picture
scene:
canada16:
Likewise- but mine is still being a cow when trying to sort out the backup path to my laptop and the kids pc- simply won't connect.
Any suggestions Scene ( sorry Canada). The online manual shows different screens as well (have you updated to 4.1.7 firmware)
canada16
canada16's picture
Thats ok, the more people that contribute the better, I am lost as well.
Going to un-install everything and see what happens.
I have a cheap buffalo linkstation, and that worked almost straight out of the box, this one is asking for server locations bla bla and upnp ect. ok you lost me now.. HA HA
__________________
scene
scene's picture
Ravey Gravey Davy:
scene:
canada16:
Not sure on the firmware update - need to check when I get home.
The big thing I found was an issue with the NAS was my firewall software (Kaspersky) - needed to make sure that the NAS was marked as a Trusted Network (inside the Firewall s/w), or nothing worked properly. Also, how are you connecting from the PC(Drunk to the NAS. I found the best way was \NAS_NameShareName - anything else seems to need various odd ports open.
__________________
Ravey Gravey Davy
From the pc/laptop to Nas is a mapped drive  m/readynas/media or   b/readynas/backup
scene
scene's picture
So if you do a "net use" from a cmd (DOS) shell on the PC/laptop, does it show you that M: \readynasmedia and B: \readynasackup are "OK" or "Disconnected"
Actually, just noticed, you're using "B:" for the backup. Don't do this. B: used to be reserved for the "B drive" - the second floppy drive, and that code goes quite deep in Windows. Choose a drive letter ABOVE the last internal drive of the PC/laptop (as below can cause another odd problem as bits of Windows will assume it's a non-network drive...).
EDIT: Strictly speaking, you don't need to assign a drive letter at all, you can just copy things directly to the UNC "\readynasackup"...
__________________
Ravey Gravey Davy
I think this is becoming so specific it is distracting from Canada getting more direct help- Mods -can you wizz the Readynas comments so far over to the new thread Readynas connection/backup issues
scene
scene's picture
+1 on that - sorry canada Embarrassed
__________________
scene
scene's picture
canada16:
Don't uninstall stuff until after you have tried things without the NAS. If it's fast without the NAS, it may not be a software issue.
__________________
TechMad
TechMad's picture
When u installed the NAS did u tell it to use its own DHCP server?
This could cripple your network performance, and cause problems accessing devices on your network.
Check the setting on the NAS and make sure its turned off.
__________________
Samsung UE55C8000, Denon 4311, Denon DBP-2012UD, PS3, Playon!HD mini 2, KEF XQ-40, AE Pro Active 5.1
Samsung UE46C9000, Samsung BD-C6900, Yamaha RX-V1067, HDX-BD1, Phillips Streamium 2900, KEF 2005.3
2x8TB NAS
canada16
canada16's picture
Will check that when I get home, I remember seeing something about dhcp
__________________
