Upgrade or replace Pro-ject Debut II
8 replies [Last post]
longwayround
longwayround's picture
I've had a Pro-ject Debut II turntable for almost 11 years now and have largely been satisfied with its sound. However as the rest of my kit has improved its flaws have become more noticeable.
 In particular, there is a noticeable rumble on some records and I wonder whether it would be advantageous to change the platter from the supplied metal one to acrylic.
 Alternatively, I have considered that it may be time to move up to a more expensive turntable such as the Rega P3 or Pro-ject RPM 5. Clearly, I don't want to be spending hundreds of pounds just for the sake of it but wonder what advice you might be able to offer.
 Cheers,
Luke
one off
one off's picture
Re: Upgrade or replace Pro-ject Debut II
the rega is the option id go for
upgrading the project isnt going to help as the noise you describe seems to be inherent in the design
longwayround
Thanks. I'm going to audition a Pro-ject RPM 5.2 at Audio-T next Saturday. (Nowhere I could find locally appears to stock the Rega, a fact which surprised me somewhat.)
The chap in Sight and Sound was quite keen to recommend a Thorens to me but is unable to demo them as they have none in stock and "didn't want to be lumbered with one"!
crimsondonkey
crimsondonkey's picture
As a previous owner I'd highly recommend a Rega P3.  You can pick them up at good prices, new or s/h.  The best thing is the arm which you can keep upgrading and should you ever wish to buy a more expensive TT you can take your investment in your arm with you!
Super TT's, easy to set up and maintain, good resale value.
longwayround
Thanks. Having enjoyed a tremendous audition of the RPM 5.2 and not having been able to find anywhere locally to audition the Rega, I've just placed a deposit on the former.
crimsondonkey
Sorry if this is a bit late, but if you're quick there's a chap (Bourney, regular wammer) on Hifiwigwam who's selling a RPM5 for about £200 ish
longwayround
Not just a bit late but also irritatingly convenient. The chap lives within walking distance of my in-laws but my cash is now with my friendly local retailer.
 Thanks all the same.
ear
ear's picture
longwayround sorry this doesn't have to do with the vinyl player but with the yamaha amp. is it good? had another amp before to compare it to?is it balanced across the range?do you like it?
__________________
Yamaha AX-397 + Yamaha NS-333;
HK 3390 + Tangent Millennium 200;
Cambridge Audio Sr10 +Cambridge audio  S30
longwayround
Yamaha AX396 Amp
Yep, I like the amp. I've had it since December 2000 and it has been my first separate amp, replacing as it did a 1991 Aiwa midi system.
As far as comparisons are concerned, I can only compare with what I've heard in hi-fi shops and I've not been tempted by other amps in a similar price bracket. For the music I listen to, which is predominantly the likes of the Kinks, the Stones, the Who and the like I'd say it's very good. Having said that, if I had a spare £500 (which I don't, having just bought a new turntable!) then I'd happily start auditioning candidates for this decade's amp.
