Shibata stylus
Fri, Jul 8 2011, 7:44PM
I'm using an audio technica AT2005 cartridge at the moment which is exactly the same as this-
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/189
I was looking to upgrade this cart until i came across this stylus from an american site-
http://www.turntableneedles.com/Needle-211-D-shibata_p_3718.html
Would this shibata styli give me a significant upgrade in sound or is changing the cart the better option?
- Login to post comments
I would suggest a better cartridge, if you have the money. The Shibata stylus upgrade fitted on your current cartridge may well extract more detail from the grooves. The longer contact area may reduce wear too. However, the greater 'penetration' in the groove can be a mixed blessing if you have older or well-worn records (or maybe collect rarities). If you mostly have specially cut or pressed 180g editions then you probably will appreciate the improvement.
The overall sound character will not change significantly, however, as you still have the same generator mechanism. And it is quite a modest cartridge.
Perhaps post the details of the rest of your system, and you may get some more replies.
Hi-Fi: Krell KAV-300cd, Michell TecnoDec/RB250/Grado Prestige Black1, KAV-300i amp, Transparent balanced interconnects and bi-wire to Sonus faber Concerto grand piano speakers, Nakamichi ZX-7 cassette deck, Logitech Squeezebox Touch, Hitachi FT-5500 and Sony S570ES tuners, BCD Engineering stand, RA Powerlink, Chord powerchord, Grado SR60i cans.
AV: Sony Bravia KDL-32EX503 telly, BDP-S370 player with QED HDMI. Currently unused: Denon AVR-1705, DVD-1710, KEF KHT1005.2
