Rega RP3
20 replies [Last post]
stevebrock
stevebrock's picture
Im really enjoying getting into vinyl again...I really love the sound!
Only had my RP1 a few months, really wish I had spent more money on an RP3....or is it just a case of upgraditis I have!
Will the RP3 sound much better? And will the Phono stage in the Brio R amp be up to the job of an RP3/Elys?
__________________
Synology DS212j > Rega DAC > Rega Brio R > Rega RS1
Rega RP6 / Exact
Chord Chameleon Plus / Odyssey 2
Panasonic TX-P50 GT50 > BDP110e > Yamaha RX-V 667 > Rega Vox
Hi-FiOutlaw
Hi-FiOutlaw's picture
RE: Rega RP3
I've spoke to my rega dealer this weekend, as my (Brio R is brend new) and I ask him is opinion on a RP turntable, if the 1 will it be enough or the difference in the price will justify the RP3?
I was told that with the sound quallity of my system and with the phono stage on the Brio R that the diference in the price would be fully justified...
And i consider him as a fully honest guy!
__________________
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
stevebrock
RE: Rega RP3
oh no!
I better get one then!
How is the new Brio R?
__________________
Rega RP6 / Exact
Hi-FiOutlaw
RE: Rega RP3
The Brio R / Dynaudio X12 combo is doing just wonderfully well!
For my listenig levels is perfect!
Maybe that just didn't come out as I hope for, that is, if i was going to spend the money for the first time then it justify to spend a litle more and go for the RP3, he even advise me to wait for a second hand in good shape.
In your case i think you just have to demo a RP3 with your gear...
__________________
LivingRoom
BedRoom
Ketan Bharadia
Ketan Bharadia's picture
RE: Rega RP3
I think the RP3 is a clear step better than the RP1 (good as it is). The Brio-R is also insightful enough to make the difference between the two obvious.
__________________
Technical Editor, What Hi-Fi? Sound and Vision
stevebrock
RE: Rega RP3
How about throwing the Inspire i2 into the mix at £369?
__________________
Rega RP6 / Exact
Hi-FiOutlaw
RE: Rega RP3
Dosn't that turn table cames with the RP1 arm?
I don't see mutch of an upgrade from what you allready have...  puzzled
__________________
LivingRoom
BedRoom
stevebrock
RE: Rega RP3
yes your right....forget about that - think i will go and demo an RP3 then sometime before xmas!
__________________
Rega RP6 / Exact
floyd droid
floyd droid's picture
RE: Rega RP3
I thought it came with a tweaked 251. And if my guess who tweaked it actually did , then my money is on it would be overall a better buy.
Hi-FiOutlaw
RE: Rega RP3
May the force be with you, my son...  beauty, eh
__________________
LivingRoom
BedRoom
Hi-FiOutlaw
RE: Rega RP3
http://www.hi-fiworld.co.uk/index.php/letters/275-july-2010.html
beauty, eh
__________________
LivingRoom
BedRoom
floyd droid
RE: Rega RP3
Hee hee.  Smile
To the OP. Unless you already have one the best upgrade without a shadow of a doubt is a wall shelf. Unless sited well Regas /Projects/ Inspires etc etc can sound bloody awful. Nature of the beast mate im afraid. Your TT may sound great to you at the minute , lob it on a shelf and start grinning.
stevebrock
RE: Rega RP3
mmmmm its currently on an Atacama Equinox rack with spikes?
__________________
Rega RP6 / Exact
floyd droid
RE: Rega RP3
Floorboards or solid floor ?. If solid not too bad but personaly I would still use a wall shell with a non bouncer , especially with an RP1 which isnt exactly ball braking in the mass dept.
stevebrock
RE: Rega RP3
yeh solid concrete floor with carpet on top!
When you say mass of the RP1....do you mean the plinth? yeh I guess its pretty flimsy compared to Rega's other TTs with the bracing.
I didnt know that all these little things could make a difference...I must say I am pretty impressed with the RP1, maybe a dedicated shelf could be something to think about if I move house!
Also does the RP3 require an interconnect? or does it already have the cables attached to it?
__________________
Rega RP6 / Exact
floyd droid
RE: Rega RP3
AFAIA the tone arm cables are fixed . By mass I was referring to the Regas lack of it ! but Gandy dosnt go down that alley. Strangely he does recommend the use of his wall shelf !, go figure.
