NAIM OR NOT
16 replies [Last post]
hawkwind90
hawkwind90's picture
SYSTEM- REGA JUPITER CD, REGA CURSA 3 AND MAIA 3 AMPS R3 SPEAKERS THE PROBLEM IS I WOULD LIKE TO ADD A TURNTABLE SO THE PRE AND POWER AMPS WILL HAVE TO GO ( THE WIFE WONT HAVE ANYMORE BOXES)I HAVE HEARD THE SUPERNAIT WHICH I LIKED AND I WILL BE UP GRADING THE SPEAKERS AND CD WHEN FUNDS ALLOW I CANT MAKE UP MY MIND AS I HAVE HAD SUGDEN AMPS IN THE PAST WITH MY WALKER CJ DECK AND THE HIFI WORLD SEEMS VERY LOVE HATE TOWARDS NAIM GEAR SPEAKERS WILL HAV TOBE BOOKSHELVE OR SMALL COMPACT LIKE THE R3S HELP
__________________
jjbomber
jjbomber's picture
RE: NAIM OR NOT
The Hi-Fi world may be love/hate towards Naim, but you liked the Supernait and that's all that matters. There is no point buying something you don't like just because the Hi-Fi World likes it. You have to buy what is best for you.
hawkwind90
RE: NAIM OR NOT
CHEERS JJ ITS JUST THAT THERES SO MUCH GOOD STUFF OUT THERE AND BEING IN MY 50S THIS WILL PROBABLY BE MY LAST BIG UP GRADE  WOT U WANT AND WOT THE DRAGON WILL LET U HAVE IS TWO DIFFERENT THINGS
__________________
Helmut80
Helmut80's picture
RE: NAIM OR NOT
I ALWAYS SAY BUY WHAT YOU LIKE AS YOU SHOULD ENJOY IT SO IF THAT IS THE SUPERNAIT FORGET ALL THE MARMITE TALK AND GO FOR IT PS NO NEED TO SHOUT AND PUNCTUATION CAN COME IN QUITE HANDY AS WELL I VE HEARD
CnoEvil
CnoEvil's picture
Online
RE: NAIM OR NOT
You need to listen to both Sugden and Naim (or even Luxman)......then pick the one you prefer.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
jjbomber
jjbomber's picture
RE: NAIM OR NOT
Don't pick on Dragons. Lots of Welsh people on the forum!
too_old_to_rock
too_old_to_rock's picture
RE: NAIM OR NOT
Spent many years keeping the wife box happy!!  Couple of suggestions
Supernait does not have built in phono stage so you may need another box anyway for your turntable.  Had you considered an Arcam FMJ A38 which can be fitted with internal phono stage. With the money you save you can virtually purchase an Arcam CD37 especially if you Purchase the two together ...should be able get a good deal. You wont get the internal  DAC of the supernait of course. Before I upgraded to my present HDX/Supernait sytem I used an Arcam FMJ A32/ FMJCD36 and they produced a very refined sound that you could listen to for hours. (I could not part with the Arcam kit and still have it as a second sytem). Arcam sound very good with Spendor shelf/standmounts also the Dali speakers so you could auditions the DALI Mentor Menuet which very compact indeed.
OR in order keep the wife happy had you considered CYRUS kit? As its half width you can stay with pre/power and if you prefer. If you use the Cyrus CD player you save more space so in the same space taken up by 2 full size units you could get a Cyrus pre/power setup , Cyrus Player and a Phono stage!. You have many specs to choose from including both integrated and preamps with on board DACS arguably your future proofed....
__________________
hawkwind90
RE: NAIM OR NOT
dont start me on the cyrus route or i,ll start looling at bel canto cheers
__________________
hawkwind90
RE: NAIM OR NOT
sorry for shouting to much hawkwind over the years and as for puntuwastion
__________________
Paul@HiFi-Lounge
Paul@HiFi-Lounge's picture
RE: NAIM OR NOT
The Supernait is a real classic and I'm sure you'll be over the moon with it if you go down that route, as an alternative it may be worth looking at the Heed kit, it's getting great reviews on WHF and other mags at the moment and for good reason, I've been borrowing their Si integrated with the X2 power supply for the last couple of weeks to listen to, if you like the Rega sound I think Heed will definately agree with you, the only way I can describe it as is extremely smooth and musical, somehow you get all the detail but it just sounds so well rounded, you can't help but be pulled into the music.
It might not be the most well known brand in this country but I would definately try and hunt out a demo if possible, I think you'll be very impressed, and as a WAF it comes in white and black, is half sized and very discrete, almost apple-esqe, you can't go wrong, I was so impressed I've decided to take them on at HiFi Lounge, actually I find most of the time I'm listening to the Heed kit other than anything else.
__________________
HiFi Lounge (Bedfordshire)
Specialists in the brands that we are passionate about!
CnoEvil
CnoEvil's picture
Online
RE: NAIM OR NOT
Paul@HiFi-Lounge wrote:
.....as an alternative it may be worth looking at the Heed kit, it's getting great reviews on WHF and other mags at the moment and for good reason, I've been borrowing their Si integrated with the X2 power supply for the last couple of weeks to listen to, if you like the Rega sound I think Heed will definately agree with you, the only way I can describe it as is extremely smooth and musical, somehow you get all the detail but it just sounds so well rounded, you can't help but be pulled into the music.
I have a vague memory of the Ion Systems Obelisk back in the 80s, which from memory, was smooth and lively...I take it this one is a "grandson" of the well respected veteran amp.
Nice to see its return.
__________________
hawkwind90
RE: NAIM OR NOT
strange you mentioned heed as id checked out there web page as whf put there amp in the top 30 amps in the august issue cheers paul.
__________________
NHL
NHL's picture
RE: NAIM OR NOT
The funny thing is that some other mag found the Heed to be a copy of some old Naim classic, and now not up to the current market standard!
chebby
chebby's picture
RE: NAIM OR NOT
Same 'DNA'...
http://www.whathifi.com/news/obituary-richard-hay-1944-2012
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
CnoEvil
CnoEvil's picture
Online
RE: NAIM OR NOT
chebby wrote:
Same 'DNA'...
Thx Chebby for the link.
__________________
malthus80
malthus80's picture
RE: NAIM OR NOT
If you like the Naim go for it. They make some stunning kit which you really grow to love. Naim does divide opinion as it is a very distictive sound but if you love it then thats whats important.
__________________
Hi-Fi: Naim CD5x; Naim Flatcap 2x; Naim Nac 122x; Naim Nap 150x; Naim NAC A5; Ipod touch 32 gig; Arcam drDock; Vienna Acoustics Bach.
Home Cinema: Sony 32 v2000; Sony BDP-350; X-Box 360 S; Onkyo 606; Tannoy Arena Lite
