My first Hi-Fi system doesnt sound quite right
126 replies [Last post]
Tariqv
Tariqv's picture
Im new to hifi and bought my system without hearing it due to limited auditioning availability in my country. I dont have a cd collection so I listen to Flac through a windows 7 laptop via Wireworld starlight usb into mdac and using the Roksan kandy k2 integrated as pre and power. The thing Im not liking is the fact that the music sounds nothing special, not inviting and fullbodied enough, this is evident especially with rock music where many fast instruments play together, you really dont get excited and satistied. Otherwise electronic music is quite enjoyable with good bass and acoustic music is even better with highs quite likeable and vocals realistic.
I believe the primary problem is the synergy of the roksan with the other equipment, it might be too analytical?!
Im thinking of auditioning a Naim 5i used in a few days, will post how that goes.
Appeciate if you could share your experience so I can improve upon my system.
__________________
Windows 7-Audiolab Mdac-Roksan Kandy K2-Tannoy Revoultion DC6T
CnoEvil
CnoEvil's picture
RE: My first Hi-Fi system doesnt sound quite right
I would also try different speakers with the Roksan....maybe Spendor, Proac, Sonus Faber, Kef R series or Opera.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
plastic penguin
plastic penguin's picture
How long have you had the system? It needs a good two weeks before all components start to sonically take shape, especially the speakers.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
ear
ear's picture
80% os that analitical sound comes from the dc6t
__________________
Yamaha AX-397 + Yamaha NS-333;
HK 3390 + Tangent Millennium 200;
Cambridge Audio Sr10 +Cambridge audio  S30
the record spot
the record spot's picture
Very much doubt its the speakers Cno, whereas the amp seems to divide opinion... the dual concentric arrangement resulted in a very musical presentation to my ears.  I listen to a lot of rock, classical, jazz... the works and the Tannoys haven't put a foot wrong.
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
BigH
BigH's picture
Online
I have heard that the Tannoys DC6Ts do need a bit of driving to get them going, so if you are are lower volumns a more sensitive speaker may be better for you.
Tariqv
Tariqv's picture
Thanks to all for your generous responses. Actually I have had the system for about 2 months now but the roksan was bought used, so they should all be well run in by now eventhough I do not play music that often. I doubt the speakers are the problem since they seem so relaxed and no strain whatsoever to the sound, but as BigH commented I do listed at quite low levels and I do feel the sound gets better and richer as I turn up the volume, and the roksan can really deliver when I do; however the main issue of not really feeling the music encapsulating me remains, t doesnt excite despite the sound being very clean and tight.
Besides, I really do not have the chance to replace the speakers firstly because of budget constraints but also because I really feel they are quite good.
I wonder if changing the amp might make a significant difference, I hear the Naim amps are very musical, so I may even upgrade to the Naim XS if that could more or less solve my problem?
__________________
dumbledore
dumbledore's picture
You should try different rock recordings. A lot of recordings can sound compressed and if so nothing the system can do to improve things dramatically. Also some speaker are less suited for rock and may sound soft. So you will need speakers that exhibit fast tight bass for rock. Not sure how the CD6T bass is like but someone here will be able to say. A soft deep bass will be good for many music types like classical, accoustical, Jazz, electronic but won't be that good for rock. To a lesser extend amplifiers may exhibit lasier bass then others. So mixing a lazy amp with a lazy speaker will be bad for bass repoduction, while mixing a lazy amp with a fast bass speaker may be a good and is a common practice to make small speakers sound just a bit more bassy. Again someone here can comment on K2 bass response.
BigH
BigH's picture
Online
I still think the speakers are more likely to be the problem than the amp. esp at low volumes. If I were you I would try and demo a few speakers with your amp, see if there is a difference. For a start try the Rega RS1s if you can, good for low volume, can sit on or near a wall.
Of course try different amps as well.
Just found a similar post back in May, saying a similar thing about Rosan/Tannoy combo.: http://www.whathifi.com/forum/hi-fi/roksan-kandy-k2-not-impresive-onkyo-tx-8050-as-an-alternative
CnoEvil
CnoEvil's picture
The speakers also divide opinion, so I thought it would be worth exploring different options......I suspect it's a synergy thing, combined with personal preference.
__________________
richiesuk
richiesuk's picture
k2 was bright for me and for
k2 was bright for me and for my gf too...
__________________
Marantz CD6004--Chord cobra Plus IC--Marantz KI Pearl Lite Amp--Tellurium Q Black Speaker Cables--Monitor Audio BX5s....happy hours Smile
the record spot
Less so than the amp I imagine.  The K2 has picked up a lot of negative comment here of late.  I imagine it probably is a synergy issue too, but I;'d be losing the amp first and speakers thereafter.  And I never liked the K2 look anyway - very Marmite!
__________________
danrv
danrv's picture
I wouldn't change the amp. It's versatile, flexible with speaker matching and a cracking amp for the money. I listen to a wide selection of music and it sounds awesome no matter what I play.
Rock is exciting and engaging with deep tight bass , clear mids and smooth treble. I'm not sure how the FLAC / MDac combo compares to the Kandy K2 CD player but I would imagine it's as good.
Give the speakers time though. Sounds like the tweeters need a bit more time to settle in. My Dali's needed more than 2 months of moderate use before they sounded their best.
__________________
Roksan Kandy K2 amp / Roksan Kandy K2 Cd player / Dali Lektor 2 / Chord Chrimson Plus / Chord Carnival Silverscreen / Atacama Nexus 6 / Target Hifi stand / Advanced Acoustics 3ft bass traps.
BigH
BigH's picture
Online
I really think you need to demo some other combos to see if there is a problem with your gear or not.
Dommer
Dommer's picture
I'd second dumbledore post. It's the Music and how it's recorded that might be the biggest factor.
I've been upgrading my system in the last 2 years. From playing FLAC out of my iMac into DacMagic + Marantz 6004 + KEF iQ10s.  To streaming into a Naim UnitiQute and a Linn Poweramp to the KEF R100s.  And I still find that a lot of Rock, especially recorded in the last 15 years sounds very flat and compressed, with little soundstage. Then there are some albums that are just amazing sounding... I think it all comes down to how they were recoded.
Try a jazz album like Katie Melua's House,  Melody Gardot's Worrisome Heart or Diana Krall's Why Should I Care and you should hear what a difference a good recording makes.
__________________
Naim UnitiQute, QED Genesis Silver spiral cables, KEF R100.
Audiolab 8200CD, QED reference silver spiral interconnects, ProJect head box Amp, Grado SR225
BigH
BigH's picture
Online
I don't know about recent rock as I don't tend to buy much of it although the ones I have bought seems OK to me, prob. depends exactly what you mean by rock? My beef is more about 70s rock which may have been early cds Im not sure but a lot of that seems poor quality, even 50s jazz sounds better. I heard some recent recordings like Linn's and also Eric Bibb's Deeper in the Well and they do sound excellent, so yes I agree I find the recording or cd pressing to be a big factor, and don't all cds sound the same even the same original album will be different on every pressing just compare one album and every version, say the Japan 1984 may be loads better than the Europe 1984 version.
