KEF Q300 placement advice
12 replies [Last post]
dmormerod
dmormerod's picture
Hi
I'm looking for placement advice on a pair of Q300's.  Currently they are 12" away from the front wall and at least 3ft from the side walls on 26" stands, but they seem a bit boomy! So I was just curious what other have done with regards to placement.
TIA
Mike
__________________
MBP -> Rega-DAC -> Rega Brio-r -> KEF Q300s
FrankHarveyHiFi
FrankHarveyHiFi's picture
RE: KEF Q300 placement advice
All rooms are different. A speaker 12" away from a wall in one room might sound nicely balanced, but 12" in another room might be booming like a boy racer's Saxo.
What stands are you using? Are the spikes and everything nice and tight? Have you tried angling them in slightly? Have you tried using the supplied bungs? Which speaker cable are you using! (not saying cable will make a huge difference, but multiple things might be adding up here).
__________________
David @Frank Harvey Hi-Fi, Coventry, incorporating HiFix
Hi-Fi and Home Cinema specialists, and exclusive UK agents for SVS and Ken Kreisel's KK Sound home theatre products.
dmormerod
dmormerod's picture
Thanks for the reply David.
My stands are SANUS SYSTEMS SF-26B Steel Speaker Stand.   I have a wooden floor so I'm not using spikes.  I use blu-tack to fix the speakers onto the top plate. I could spike the top plate.  The speakers are toe'd in.  I've not tried the bungs yet, that was my next thought before moving them further into the room.  My speaker cable is some old K20 Linn.
__________________
chebby
chebby's picture
Use the floor spikes.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 4 32GB • iMac • Panasonic TX-L32D25B • Sony BDP-S390 • Vita Audio R1 MkII • Humax HDR-Fox T2
THESTIG08
THESTIG08's picture
how long have you had your speakers/electronics? it could just be a case of running in.. the kef q's take an age to fully run in.
__________________
Pioneer Blu-ray -> Media Pc -> Rega Dac -> Rega Brio-R -> Kef R100 -> Partington Super Dreadnoughts -> Chord Odyssey 4 -> Chord Chameleon Silver Plus & USB -> Chord Prodac x2 -> Logitech Harmony One -> Spotify Premium
dmormerod
dmormerod's picture
@chebby - thanks ill give it a try with a coin under the spikes!
@thestig08 - I've had them a couple of weeks so they probably have 50-70 hrs on them so far.
Thanks for the input everyone, time to go experiment!
__________________
FrankHarveyHiFi
As Chebby mentions, it's worth trying the floor spikes, as any movement in that stand will result in a ill defined bass, which could come across as a bit boomy.
__________________
THESTIG08
THESTIG08's picture
they need more time imo, mine took a good couple of months before they tightened up.
__________________
HDNumpty
HDNumpty's picture
I have Custom Design stands, I bought their own floor protectors, £40 from a dealer in 2006 but cheaper from their own site.  hey are chrome plated and work fine with my oak floor
__________________
Music: CA 740c & 840a, B&W CM1s, iPod Classic 120gb, Onkyo NDS-1, Spotify Premium
Movies: Pana 37" plasma, Sony BD, Humax Foxsat HDR, Sony DA-2400ES, MS surrounds, REL Sub
Mobile: iPhone 4, Sennheiser MM50/iGrado/AKG K450, Apple Lossless, Spotify, iPlayer
dmormerod
dmormerod's picture
Just thought I'd update.
I spiked the stands onto pennies (for now at least) to protect the wooden floor,  dumped the blutack and spiked the top plate, move the speakers another inch or so out from the front wall and the difference is huge!!  So thanks everyone for the advice about the spikes, it's worked wonders, the bass is way more controlled.
Mike
__________________
jimm
jimm's picture
I use blutack to hold them in place on my stands, so can you buy spikes for the top plates of your speaker stands? i didnt know that it can make difference..
__________________
Musical fidelity m1 - Roksan caspian m1 - Dali lektor 2
Musical fidelity v-can 2 - Grados sr80i
dmormerod
dmormerod's picture
Yes, my stands came with little grub screw spikes for the top plate that you adjust with an allen-key.
__________________
FrankHarveyHiFi
Spikes for the top plate don't tend to make as much difference as the floor spikes as they're not as sharp, but decoupling the stand from the top plate can have its benefits, so trying the top spikes will be worth it.
I'd be careful with blutak as it can pull veneer of speakers when you're trying to take them off the stands if you're not careful!
__________________
