Cyrus Two Or NAD 302
9 replies [Last post]
SeanRussell
SeanRussell's picture
I already have the Nad 302 Powering a pair of B&W DM110 but I have the chance to pick up a Cyrus 2 for a small sum of money, I have always loved the Cyrus sound ever since hearing a Cyrus 3 with a pair of B&W Dm603s . Would this be a upgrade from what ive got? Also have noticed that the high frequencies and music with lots going on becomes merged together could this be the the stupidly cheap CD player im using or the speaker and Amp combo?
Any input is welcome Thanks
__________________
HIFI- Amp Cyrus 3, Speakers B&W DM110, Source PC lossless files
Need- Beresford TC-7520, Acoustic energy 109
SeanRussell
RE: Cyrus Two Or NAD 302
Or a Cyrus 3 Maybe ?
__________________
MajorFubar
MajorFubar's picture
Cyrus 2 is very detailed but sometimes a bit too forward for some, depending on your tastes and speakers.
Their value is fairly static so if you don't like it I doubt you'd sell it at a loss if you didn't like it, especially if you're getting it cheap.
Which version is it? The One and Two passed through seven (I think) incarnations over 9 years. The later ones are the best, with a flick-switch on the front and full-metal build, even though their Nextel paint is prone to flaking on the fascia.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
SeanRussell
Thankyou for the reply, it is the Cyrus 2 with the flick switch and the metal casing, Would it be worth spending a little extra on the Cyrus 3 or is there any othere alternatives such as the Audiolab 8000A. I listen to mainly folky and indie music at medium levels of volume
Thanks again
__________________
MajorFubar
Yep that's (allegedly) the best one.
8000A is a great alternative which might be right up your street if you prefer a smoother approach. Plus it has tone controls. Both of them should be fine with indie, but one of them will suit your tastes better than the other, and it's difficult to say exactly which. Unfortunately I haven't heard a Cyrus 3, so I've no idea how it compares.
__________________
SeanRussell
Thankyou I might give the Cyrus 2 a go and if I dont like the sound then I can always sell it and get my money back. have you heard it with the PSX ?
__________________
MajorFubar
I have.  If you like the Cyrus 2 on its own you'll love it with the PSX, but if you don't, then you won't, because the PSX doesn't change the amps sonic character, it just adds, well, more of everything (sorry that's very vague!)  To use the PSX you need to remove two inline glass fuses from the Cyrus 2's circuit-board.  It's dead easy, but you will need a torx screwdriver to remove the lid and a pair of pliers to remove the blanking-cap from the PSX socket.
I'd love to hear what you think of the sound; it's very 'Marmite'.
__________________
SeanRussell
Thanks for the advice, sorry for the late reply ive been making some speaker stands  excellent! I will let you know what I think about it, Hopefully if its anything close to the Cyrus 3 ill be on to a winner
__________________
MajorFubar
Oooo get some photos up...we'd like to see those!
Some say that the 2 is better than the 3, especially if you are a vinyl lover.
__________________
SeanRussell
Bases and platforms are finshed out of 4inch thick ash, Hope there sturdy enough excellent! I will most probably finish them tomorrow, I will try and get some pictures up. Unfortunatley Im not into vinyl although I do like some skipping and scratching once in a while
__________________
