Best Hi-Fi upgrade ever.
15 replies [Last post]
Mr Beachams
Mr Beachams's picture
And cheap as chips, just how many people use them before an audition?
__________________
Shanling CD-T80, Jolida JD1501P Hybrid, Morel 602's (Hand built & modified)
   LESS IS MORE!
tino
tino's picture
Online
RE: Best Hi-Fi upgrade ever.
Be careful you don't poke them in too far otherwise it could end up being the worst hifi downgrade ever.
__________________
Squeezebox Touch | Wadia 151 | Aliante Moda PF
Stereolad
Stereolad's picture
Just don't put them in your ears. Seriously, you shouldn't put anything in your ears and there is no need to.
drummerman
drummerman's picture
I think the last two I used are still in there ... amongst other things.
Must be a cavernous space between my ears.
regards
__________________
Pretty ... and pretty proud of it
Hi-FiOutlaw
Hi-FiOutlaw's picture
That is a DISGUSTING photo !!! Tongue out
__________________
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
alchemist 1
alchemist 1's picture
  Quote. '' Stop when there's resistance ''  unquote........poke, prod
simon3102000
simon3102000's picture
Jesus man do not recommend people stick things in their ears, doing that regularly will damage your ears, and more than likely compact the gunk in there even more, this post should be removed.
__________________
imac 2011, Airport express, DacMagic, NAD C326 amp, Wharfedale Diamond 10.1 speakers, Soundstyle Z1 speaker stands, chord cables, Tacima power conditioner. Controlled with my iphone 4S...
Triggy
Triggy's picture
I was told by ENT Consultant that "nothing smaller than your elbow should be put in your ear".
Serious damage can be done by using these cotton buds.
__________________
Cyrus 8XP (with Ianmac filter) & PSX-R/Cyrus X Power/Cyrus CD 8SE2 & PSX-R/Denon TU1800 DAB/Sony MDsJE530/MA RS6 speakers/Tellurium Q Black, Chord Chorus2, Chord Cadenza, Chord Cobra3 interconnects/Tellurium Q Black speaker cable/Tellurium Q Black Links/Clearer Audio Copper-Line Alpha mains cable/Black Ravioli pads/Entreq Minimus
the record spot
the record spot's picture
Indeed.  And I'm assuming that was ears they were poked in.  *cough*
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
steve_1979
steve_1979's picture
I'm starting to get a bit worried reading this thread. Sad
I use earbuds every day to stop the Comply foam tips on my earphones from getting dirty.
If I stopped using earbuds to clean my ears I'd have to start using regular rubber tips on my earphones instead because they're easier to clean when they get waxy.
__________________
PC > AVI Neutron Five 2.1
the record spot
Thanks for the tip Steve.  I'll retire the wire brush and Dettol in that case now.   Smile
__________________
steve_1979
Ooops. embarassed
I ment to say I use "cotton wool buds" to clean my ears. Not "ear buds".
__________________
matthewpiano
matthewpiano's picture
Using cotton buds to clean ears is dangerous.  It compacts some of the wax causing it to harden and increasing the risk of infection.  There is also the danger of going too far in and perforating an ear drum.
The only way to get rid of excess wax is to consult your GP who will be able to give you some drops to soften the wax and then syringe your ears.
__________________
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
Hi-FiOutlaw
blark !!!
Thats even whorse... If so, from who then...? Any suggestions...? Wink
__________________
LivingRoom
BedRoom
Triggy
Triggy's picture
Syringing is now out of favour.  Many GPs and Practice Nurses prefer to wash out ears with a flow of water under lesser pressure than syringing.  Another way is to vacuum the excessive wax out....I kid you not!
__________________
Ian64od
Ian64od's picture
What about Ear Candling?
__________________
Olive 04HD
Cyrus 8xpd qx
Spendor A6
Denon TU1800 DAB
SEE Revolver TT/CA 540/Ortofon 2M Red.
