SONY PS3 VS Blu Ray Players
12 replies [Last post]
STUARTWILLIAM
STUARTWILLIAM's picture
Hii want to buy a blu ray player, but i don't know if i would be wasting cash. as i like playing video games on my ps3, but i want to get the best out of my blu rays. i have a Samsung plasma PS-42S5SD it can handle upto 1080i high definition in picture. i have a hdml lead and a budget in mind for a blu ray player. any info on the blu rays below would be great, are they better picture quality,better upscaling and Sound etc than my Sony ps3, any help to these players or questions would be great. thanks a million??Sony BDP-S390Sony BDP=S370Sony BDP-S380Samsung BD-E5500Panasonic DMP-BD75
__________________
bigboss
bigboss's picture
Online
RE: SONY PS3 VS Blu Ray Players
My suggestion: buy the PS3 first for your games. Then compare blu ray / DVD performance with other players. In my experience, I found no difference in blu ray picture performance between the PS3 & higher end players. PS3's DVD upscaling is also very good. The only reason I went for a standalone blu ray player, is due to PS3's fan noise (as my AV system is housed in a closed cabinet). If that's not an issue for you, you may well be happy with your PS3.
__________________
STUARTWILLIAM
RE: SONY PS3 VS Blu Ray Players RE: SONY PS3 VS Blu Ray Players
ok thanks for the reply. i was just making sure my ps3 was giving me the best experience for my blu rays.
__________________
AnotherJoe
AnotherJoe's picture
+1 to that. I cant say I've really noticed any difference between my PS3 and Denon/Panny BDP's when playing BDs.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
STUARTWILLIAM
Thanks for your info that helps me out alot, i have the same problem with my ps3 fan noise
__________________
bigboss
bigboss's picture
Online
Let us know if you want to buy a new player & your budget, & your desired features (DVD upscaling, SACD etc.) & we can suggest you options. Good luck!  Smile
__________________
STUARTWILLIAM
Yes i would be looking for a good blu ray player for under £200, i would be looking for the sound quality to be as punchy as the picture performance,and get the most out of the upscaling, my desired features would not be a big thing as long as their was firmware updates the player looks elegant and a fast startup and loading for my blu rays i would be happy. and thanks for any advice you can put my way.
__________________
bigboss
bigboss's picture
Online
What's the rest of your system like?
__________________
STUARTWILLIAM
Samsung PS-42S5SD has a few small plasma flaws but nothing major,42S5SD can handle 1080i picture but the panel resolution is merely 852 x 480
__________________
bigboss
bigboss's picture
Online
You don't have to spend a lot on your player. As your TV's resolution is low, the amount of upscaling DVDs is also less, so DVD pictures will be good. Do you have a sound system? If not, your TV's speakers will not bring out the differences in sound between players. Look at Sony S390 / Panasonic BD75 / BD77 / BDT120.
__________________
sollie
sollie's picture
Hello all (and stuart) . I'm searching for a new player myself these day's, so I stumbled over this tread.
A while back I got to borrow both the philips 9600 and the denon 1611 when they werw new on the marked. I had just got the samsung 46' lcd 750(755) model and I wanted to 'try' and se if I could notice any hughe steps in PQ over the good old 60 gig ps3
http://www.avforums.com/forums/blu-ray-dvd-players/1386079-ps3-vs-denon-1611-philips-9600-bd-player.html
ore in Norwegian(for pic's)
http://avforum.no/forum/dvd-blu-ray-spillere-opptakere/110033-denon-dpb-1611-vs-ps3.html
http://avforum.no/forum/dvd-blu-ray-spillere-opptakere/109925-philips-bdp9600-vs-ps3.html
I hope one is abel to se the pic's without loging in. But I concluded with that the ps3 was equal ore slightly better on BD than Denon 1611,and was a foot behind on the philips. Cd sound was not tested as I belive both the denon and philips( did) would trash it. On dvd philips did the best job. I used sky blue from PG growing up to compare since the blu light at the start of the song is really 'crowded with ants' if you understand me  Smile
Back when I did this little test I choose to return both and stick¨with the ps3 a while longer. The denon just felt cheap, and I have later read and heard that few of the philps player worked any good, with a good amount of returns and fixed for many buyers.
Theese day's my DV6400 from marantz is acting up, and the ps3 is getting old so I'm looking at the CA751, wich seems , a little overkill for my system, like a rocking player with good cd audio to. And also the marantz 5005 wich is at a great price at my local dealer now since the 5007 is out. But it has a fan, and while some are loving , some are not so pleezed with it. Beeing more pricy than Denon while it's the same thing( they look alike, at the back atleast Smile )
not easy this Smile
STUARTWILLIAM
No i don't have a sound system at the moment it's something else i'm looking into, thanks for your advice on the blu ray players i will look into them and let you know what i choose (-:
__________________
STUARTWILLIAM
Hi Sollie
Just after reading your link thanks for your info, gives me lots to think about!
__________________
