8 posts / 0 new
Last post
20520988's picture
Last seen: 2 years 4 months ago
Mains Hum
  I have fitted an extension Phono lead from my turntable to my amplifier and  now have mains hum. When I touch the extension lead at the connection the hum stops. How can I stop this ?
abacus's picture
Last seen: 2 hours 20 min ago
Could be a faulty cable, or
Could be a faulty cable, or the additional ground lead fitted on most turntables has become disconnected.
Hope this helps
Bill
macdiddy's picture
Last seen: 1 day 13 hours ago
Mains Hum
Hi there.
Sounds like you may have a grounding issue, this is why when you touch the connection the hum goes because you are acting as the ground, you don't mention what turntable you have but most come with a third ground wire in addition to the audio connection.
My question to you is did you extend this wire as well as the audio connection.
Hope this helps.
20520988's picture
Mains Hum.
I have fitted new Phono plugs to the leads on my Rega Planner 11 turn table and am using an extension lead from this cable to my amp. but I have not noticed any third wire ?
Ron
20520988's picture
Mains Hum
I am not aware of any ground lead other than the earth wire on the power supply.
Ron
GeoffreyW's picture
Last seen: 6 days 1 hour ago
There should be a third, thin
There should be a third, thin, wire, between the two phono cables of the TT output cable, rather like the earth wire in the grey mains cable. It should have a spade terminal fitted, for binding/securing to the Earth terminal post of the phono amp. If it's not visible readily, you may have to look closely at the TT output phono cable, between the two main wires. If you bought the TT new, then it should still be there, but if it's S/H, it may have been removed/broken off. Hope this helps.
Rega RP3  Nagaoka MP110  CA640P  NaimUniti   NAC A4  Royd Doublets  B&O H6  Alessandro MS1   Panasonic TX-P42G15B   Panasonic DMR-BWT720  Humax HDR-1100S
AmigaNut's picture
Last seen: 2 years 2 months ago
GeoffreyW wrote:
Rega's do not have an earth wire, they are earthed internally.
AmigaNut
GeoffreyW's picture
There is an earth wire, as I
There is an earth wire, as I described, on my Planar 3, hence my reply. Presumably things have changed since I bought it (1983)?
Log in to post comments
