22 posts / 0 new
Last post
silversid's picture
Last seen: 1 year 5 months ago
HP Laptops
Looking for a new laptop and was thinking of getting another HP, my old one has lasted 7 years, but some reviews I see now are saying HP are not a good make any more is this correct?
What other makes should I be looking at or are HP still a good make?
expat_mike's picture
Last seen: 3 weeks 6 days ago
RE: HP Laptops
What criteria do the HP laptops get the "bad" ratings for?
The laptops of choice for my employer, used to be Fujitsu-Siemens, but are now HP. Maybe HP laptops do well on criteria such as robustness and reliability, but badly on criteria such as weight or sexy looks.
You need to tells us more about what your requirements for a laptop are, before anyone can give you advice.
jjbomber's picture
Online
Last seen: 2 days 15 hours ago
RE: HP Laptops
Got 3 Hps. They are fantastic value for money and very reliable. They don't have a sexy tablet for showing off, so get knocked for that reason. Do what is best for yourself rather than some numpty writing a review.
silversid's picture
RE: HP Laptops RE: HP Laptops
I dont usually listen to reviews but never bought a laptop for a few years so I want to buy a good one.
It'll be used for surfing, storeing photos/movies but unlike my previous HP I'd like to connect it to my TV, so I can view my photos/movies and watch sky go.
This one caught my eye and in price.
http://www8.hp.com/uk/en/products/laptops/product-detail.html?oid=6792912#!tab=specs
Well it does have a HDMI port, which I presume you would use to connect it to your TV.
My questions are:
1 - The screen resolution is 39.6 cm (15.6") diagonal HD BrightView LED-backlit (1366 x 768), so does it display your photos/movies at the same resolution on the TV (ie not full HD)?
2 - It uses an i3 processor. I know someone who says that it is fine for his surfing, and for streaming content to his TV. Maybe it is just me, but I would prefer an i5 processor.
silversid's picture
My questions are:
1- TV is full HD so am not sure about that.
2- i5 might be out of my price range.
silversid's picture
RE: HP Laptops
I've found this for sale its a second hand one though, don't if that will be a problem.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02267117
RE: HP Laptops
My only experience would be that I bought my Ipad as a refurbished item from Apple, and have had no issues, so second hand can be a good buy.
Things to check are:
1 - has the battery been replaced? You don't want to buy a laptop that was returned because the battery was duff, and hasn't been replaced.
2 - The display is 39.6 cm (15.6") diagonal High-Definition LED HP BrightView Display (1366 x 768). Will this display as full HD on your TV?
silversid's picture
RE: HP Laptops
Its still on its original battery, the laptop is coming up 4 years old.
The person that is selling it has had it from new.
RE: HP Laptops
The battery is your big risk - however are you going to use the laptop as a desktop replacement, or will you use it as a mobile device away from base (ie how much will you need to use the battery power - a little or a lot?)?
silversid's picture
RE: HP Laptops
Well my old HP that I'm replacing hasn't had a battery for the last 2 years, its been a bit of a pain but I have just got used to it.
Other than the battery might be on its way, is it a good spec laptop?
pauln's picture
Last seen: 6 days 9 hours ago
RE: HP Laptops
Apart from the screen it's OK for what you say you're going to use it for. That's quite low res for a 15" display, you'll be doing much scrolling.
RE: HP Laptops
In that case, the battery will not be an issue. My laptop is 11 years old, and the battery no longer holds any charge, so the laptop is always connected to the mains. Like you, I don't find that a problem now.
The i5 processor will be powerful enough for most things, and you will have a HDMI port to connect to your TV.
Only you know if that screen resolution is big enough for you - I would be looking for something nearer full HD.
silversid's picture
RE: HP Laptops
Thanks for your help everyone I'll have to think about the screen res a bit longer, would a 17" with 1600x900 be a lot better or has it to be full HD?
Off topic could I ask expat_mike in your sig you have a Panasonic DMP-BDT310, could you tell me what’s it like I'm thinking of buying one.
pauln's picture
RE: HP Laptops
That would give you more pixels (i.e. more of the web page/spreadsheet/photo/document would be visible) on the display but the display would be bigger so no real gain in resolution. 1600 x 900 @15" or 1920 x 1080 @ 17" would be my choice. Depends what you want to do, if you are editing photos for instance, you can't get enough pixels so that your tool palettes don't obscure too much of the image. If you are only going to look  at photos/video via a TV screen or external monitor then it doesn't really matter what your laptop display is.
RE: HP Laptops
I use the Panasonic DMP-BDT310 for all my DVDs and Blurays, and I think it is in it's "out the box" state, so I haven't modified any of the settings. I only watch 2D films, so I cannot comment on the 3D performance.
Anyway for 2D discs, the DMP-BDT310 does all i need it to, because the picture and sound are both excellent, and I am happy to keep using the box.
The only downside that I have discovered, is that it doesn't play SACD discs. I bought a couple of hybrid SACD discs a few months ago, and discovered that I cannot play the DSD stream using the Panasonic. Consequently if I was buying a bluray player today, I would consider a Sony, but only because they can handle SACDs. If SACDs are of no interest to you, then I think it will be difficult to beat the panasonic picture quality, at the price at which it now sells (approx £120).
I hope this limited feedback is helpful.
Pages
Log in to post comments
