15 posts / 0 new
Last post
Mikejekel's picture
Last seen: 2 years 3 days ago
Rega brio-R + Rega DAC vs Rotel RA12
I am listening to my current set-up for a bit over a year now. I am reasonably happy with it but I would like to see if it could be better. I wonder if the brio's 50 wpc is enough to drive the dyns to the full potential. Then there's the humming and sometimes brightness. Also the Apple TV only supports 48 kHz so it is upscaling.
Can I replace the brio, dac and Apple TV by the rotel ra12 without losing functionality and increase sound quality? This way I have digital input, mm input, add 10 wpc and pre-out for future upgrade possibility. I do not really understand how the Bluetooth works. Can I stream via airplay from iPhone to rotel?
thanks for helping out.
Rega RP1 - Rega Fono mini - Apple tv 2 - Rega DAC - Exposure 2010S - Chord Odessey 2 - Neat Motive 2SE
unsleepable's picture
Last seen: 1 year 1 month ago
RE: Rega brio-R + Rega DAC vs Rotel RA12
Mikejekel wrote:
I wouldn't be concerned about the Apple TV. It doesn't seem to suffer from jitter issues as some as some of the Airport Express models. Also, I've read reviews according to which they were not able to hear differences due to the frequency upscaling. And actually, Peachtree recommends it as a streaming solution. So unless you'd like to play higher-resolution music, I think I would say it's an excellent solution.
And the Rotel RA-12 only supports Bluetooth for streaming, right? If you intend to use that protocol, it will definitely be a lower quality solution.
Naim DAC-V1 • Arcam P38 • Kef R500
Leeps's picture
Last seen: 6 days 15 hours ago
I'm no expert on this, but my understanding is that if you own Apple products, then Airplay rather than Bluetooth ought to be the higher quality wireless streaming method.  Bluetooth at its best requires that your phone/tablet supports the AptX standard. My ipad supports Bluetooth, but not the higher quality AptX, which is why I was drawn to Airplay.
Tidal, Cambridge 640CD, Pioneer BDP450 Bluray, Pioneer VSX-2021 AV receiver, Ruark Talisman III, Ruark Dialogue II centre, Ruark Epilogue II rears, MA R370HD sub, Panasonic TX-P42G30B plasma
Even when both source and receiver support apt-X, AirPlay is still a better protocol for audio.
Hi-FiOutlaw's picture
Last seen: 2 weeks 1 day ago
i feel really comfortable to talk about the "brightness" in your system, i had exactly the same system, Brio R/Rega DAC/X12/ATV3 for Spotify through ipad2.
First and before spending any unecessary money, you should try to change speaker cables, i've demo a dozen and always had the best results with cooper cables, deno 1 or two before spending money on new gear.
Rega Brio R and X12 really don't get along with silver cables and some times you may fell brightness in your system.
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
CarlDW's picture
Last seen: 2 months 4 weeks ago
I don't believe that the Rotel is going to be an improvement over the Brio-R, the Rega is a more musical amplifier.
Also you will only be able to stream to the Rotel via Bluetooth, and not Apple Airplay.
Yamaha MCR-140; Audio-Technica ATH-M50X
thats true as well, i've upgrated the brio R for a Pathos Classic one, now i'm extracting every bit of the Dyns X12.
the Brio R is a wounderful amp, it can drive the Dyns very well, even at low volumes, but if you want a real up grade you have to step up a little bit in the food chain. You have to look for amps with more 20/30 wpc.
Mikejekel's picture
Hi guys,
thanks for the replies. I now realize that using the rotel for streaming over the atv is compromising on sound quality. Still leaves the option of replacing brio+dac by the ra12 and keeping the atv for streaming. Gives me the extra wpc and the pre out.
Then you say rega will beat the rotel on sq so I would need to do ab demo to find out.
@hifi outlaw, I believe despite the name the silverscreen is actually a copper cable. What cable worked out for you in the end?
thanks again.
Mikejekel's picture
Btw, I don't want to spend a lot of money here. I believe I can sell the dac and brio for the price of a new rotel ra12
@hifi outlaw, I know you used to have the same set-up. It was the reason for me checking the x12 in the first place. I also read your thread on replacing the brio and the demo's you have done. That's what got me thinking again. This time without spending the same amount of money though.
The cables that i've ended with are Inakustik LS1108, but they do have a new range now.
what filter do you use in Rega DAC? I find the 3 with more bass and not so edgy.
Try to find another cooper cable, demo some more brands if you can, i think you will not regret it.
stevebrock's picture
Last seen: 1 day 6 hours ago
in other words you need a valve amp to take the edginess off that Brio R
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
I think that the OP don't need such "radical" move, a simple cable change might work perfectly, worked for me! And not only in the uper treble, it did change the bass contrlole over the Dyns, giving the impression that more power were reaching the Dyns, I reamember writing that some where in here.
Mikejekel's picture
Never heard any valves but that sounds like something for a future upgrade path.
These speaker cables you mention hifi outlaw, I can only find them for 500,- eur. Seems a bit too much.
I think i just need to ab test both configurations. When they are equal, I think I will go for the rotel option since that offers the possibility to upgrade to a pre power configuration. I expect to sell the rega combo for the price of the rotel.
I was not suggesting that you got the same cables i did, i was suggesting that before spending your money in a new amp you should try some different cables in your system, before speanding money in a new amp.
Rega Brio R and Dynaudio loud speaker are very sensible to different cables.
In my opinion the Rotel will not favour the X12,it is not warm as the Brio R and will only accentuate your problem...
it's your money...
CarlDW's picture
I agree. Personally the Rotel is a sideways move (maybe even a downgrade sound wise).
Log in to post comments
