30 posts / 0 new
Last post
BigH's picture
Last seen: 2 months 6 days ago
CD transport
I would like to demo some cd transports but don't know many apart from the Cyrus 6SE2, can you suggest any others upto about £800.
Listen to the music, not the hifi.
richardw42's picture
Last seen: 1 week 3 days ago
RE: CD transport
Musical Fidelity M1 CDT.
Do you really need to spend that much. What are you putting it into ?
BigH's picture
RE: CD transport
Thanks for the MF.
Do I need to spend that much? Well that is why I need to try a few to test the difference between a decent transport and my old Marantz 63SE cd player and a Sony Blu-Ray DVD player. It will be going into a DAC either a Rega or Cyrus/Musical Fid. or into an AVI AMD9RSS.
I believe my dealer has both the Cyrus and Musical Fid in stock.
stevebrock's picture
Last seen: 6 days 17 hours ago
RE: CD transport
try an Apollo R?? I did and i think it sounds great!
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
chebby's picture
Last seen: 1 hour 56 min ago
RE: CD transport
...or even find out if there are still any NOS Rega Apollos (pre 'R' version) you could pick up for a discount.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
BigH's picture
RE: CD transport
Thanks I will be trying the Rega anyway, their whole system, just wanted a few ideas for transport only as the integrated player has a dac in it so seems a bit of a waste of money having 2 dacs in the system.
Prob. start with Marantz 6004cd, Rega Amp, Rega RS1 speakers. Then add a Rega DAC, then change cd to Rega.
I see my dealer does not do Cyrus but they have MF.
Electro's picture
Last seen: 1 week 5 days ago
RE: CD transport RE: CD transport
What about one of these Little dot transports from china , they use a good Philips mech and seem well built at £224 including postage .
http://www.ebay.co.uk/itm/Little-Dot-CDP-I-CDP-1-CDP1-CD-Transport-with-Remote-Control-digital-display-/180729428720?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item2a14503af0
if you scroll down to the pictures there is a de-constructed one to look at .
They have some good feedback from users on other forums so it might be worth investigating Smile
 Electrocompaniet EMC 1 UP ,  Cambridge Audio id 100 i pad dock, ipad with Spotify premuim, Monarchy Audio DIP, Electrocompaniet ECD 1 dac , EC4.8 preamp , 2x AW180 monoblock power amps , PMC PB1i speakers . Thousands of Cd's .
BigH's picture
I was looking at Little Dot yesterday but problem is you can't hear them first and if it goes wrong you have to send it back to China I believe?
Electro's picture
Yes that is the down side of these Chinese products .
Failing that I would recommend any transport or cd player that uses the Philips CD pro 2 mechanism, it is one of the best and most reliable transport mechanisms ever made .
BigH's picture
But was that not the problem Cyrus had with their cd transport a few years ago?
Electro's picture
No the Philips Cd pro 2  is a top loading mechanism and as far as I know has never been used by Cyrus .
It is usually found in very good quality transports and cd players and commercial players found in recording studio's and even the commercial juke box machines found in pubs etc because it is so reliable and strong .
http://www.armoniahifi.com/EN/CD1.html
http://www.dutchaudioclassics.nl/Philips_cdm12_cdm-Pro/
The Musical fidelity A1 cd pro uses this mech .
http://www.hi-fiworld.co.uk/cd-dvd-blu-ray/62-cd-reviews/189-musical-fidelity-a1-cd.html
BigH's picture
OK thanks for explaining, I will be checking out MF, does the Rega use the same Philips?
Electro's picture
I think Rega use Sanyo and Sony mechanisms , as far as I know they have not used the Philips Cd pro .
Here is a list of most manufacturers and which transport mech's they use .
http://www.dutchaudioclassics.nl/the_complete_d_a_dac_converter_list/
El Hefe's picture
Last seen: 6 months 1 week ago
RE: CD transport
When you try the MF CDT, request for it to be connected to a DAC via both the coaxial and AES/EBU and compare them.
FM radio
BronC's picture
Last seen: 2 years 6 months ago
RE: CD transport
BigH wrote:
Thanks for the MF.
If you notice a significant imrovement then i would suggest buying a better 2nd hand version of the cyrus transport.  You should be able to pick up a good 2nd hand Cyrus CD XT SE 2 (their top CD transport)  for that type of money
datay's picture
Last seen: 2 years 8 months ago
RE: CD transport
The CD6SE2 isn't a transport, it's a full player. The CD T is Cyrus's entry-level transport, in your budget; the CDXTSE2 as already mentioned is the much more expensive version, takes external power supply as optional.
Musical Fidelity M1 CDT is around the same price if not slightly less. You'd have to audition to establish any SQ differences, especially with your own dac.
Heed do a CD transport but I think it's north of £1k. Little Dot as mentioned are much cheaper and lots of user reviews if you google.
Pages
Log in to post comments
