"pulsing" FM interference
10 replies [Last post]
Steven Wilcox
Steven Wilcox's picture
I have a Musical Fidelity kw250s combined CD/Tuner/mono block amps unit.
I have a roof top aeriel and although I much prefer the quality of sound on FM to DAB I am getting a pulsing interference on FM.  It's not noticeable on louder music but can be annoying in quieter classical passages.  The interference consists of a fairly quiet noise pulsing about once per second.  I also have a problem with what I believe to be DC on my mains supply that is causing the tarnsformers to buzz and I wonder if the two things might be connected?
 Any thoughts on what the problem is likely to be, and how to rectify it would be very welcome.
fatboyslimfast
fatboyslimfast's picture
Re: "pulsing" FM interference
Have you got any mobile phone chargers plugged in? If so, remove them. I had exactly this problem and removing them from the plug sockets solved the problem.
It could also be another type of charger - laptop etc?
__________________
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
Jim Highfield
Jim Highfield's picture
I had a similar problem when we were on the BARB panel. It was their box.
Andrew Everard
Andrew Everard's picture
So assuming you are on the BARB panel, there's your solution.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
chebby
chebby's picture
Has your rooftop aerial connections been checked lately? Do you have good quality 75 ohm double-screened coaxial cable? Maybe you are not using an optimum aerial type for your local reception conditions.
Check out this excellent guide first... http://www.aerialsandtv.com/fmanddabradio.html
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Steven Wilcox
Thank you for the suggestions.
 I'm not on the BARB panel - I had to look up what this is as I'd never even heard of it.
 I've tried disconnecting all chargers but this hasn't worked I'm afraid.
 So, any further suggestions still welcome.
Steven Wilcox
Chebby -thanks for your comments also - I was writing my response to the previous comments as you were posting yours!
 I only quite recently had a full aeriel instal but wasn't very happy with the job done - the freeview reception was very poor in some rooms and I had to get another installer in to check it out.  They installed a couple of new sockets which seemed to help for a while but the freeview reception from one room is now poor again - even though the aeriel has a line of sight to the transmitter only a few miles away.
The FM aeriel for my MF Unit is actually plugged into the TV wall socket as it gets far better reception from this than the one marked FM.  I've yet to try a TV in this room so don't know if this will work in the FM socket.
I think I may need to get an installer out to do a thorough check - as it happens the organisation whose website you refer to is in my home City (Sheffield) so I may even try them - they certainly seem to know what they're talking about and are keen to supply quality products.
mjw999
mjw999's picture
Steve
I live near Sheffield and also run a Pure FM tuner from the TV aerial (since I had a freesat dish installed). Mine works just fine. Just trying to save you the money for engaging a contractor (£75 just to visit?) - check again for household causes.
The buzzing in the casing - if it doesn't come out of the speakers, you can get that from the ring main (Naim stuff is especially prone) - hi-fi power from a spur can help a lot.
If you've turned all the phones and chargers off, have you thought the tuner might be at fault? - some kind of electircal component 'leaking' current? (I really have no idea what I'm talking about now). Could you borrow a mate's tuner and run it from your aerial to check?
Just a few thoughts
Mick
Steven Wilcox
Thanks for your thoughts Mick.
 I've got an Arcan tuner in another room and the reception is fine from the same FM aeriel.
 I think the buzzing from the amp transformers is probably caused by DC on the mains - not so easy to solve unfortunately.  There's a few Units out there that might do the job but very expensive - Alan Clarke at James Audio has been particularly helpful with his advice and has a Unit that he is confident will sort it out but it's about £700 which I just can't afford at the moment.
Steven Wilcox
RE: Digital and analogue radio
Thought I'd just add, some 3 years later, that I bought the James Audio power conditioner unit shortly after the last post and it has been working very well indeed.  The buzz was reduced to a virtually inaudible level - it's certainly not a problem now.
aliEnRIK
aliEnRIK's picture
So a 'mains conditioner' had the effect of reducing audible noise?
__________________
Marantz AV8003 Pre Amp. Musical Fidelity A5 Power Amp. Arcam P1000 Power Amp. Monitor Audio Silver 8i and surrounds. Oppo 95. Sony 46W5500. PS3. 16 core braided mains cables. Atlas Titan and Ascent cables. Isotek Sigmas. Balanced mains transformer.
