Replacement stylus or cartridge?
6 replies [Last post]
gbhsi1
gbhsi1's picture
Hello,
I currently use a 2m cartridge in my turntable but I am thinking of upgrading it to either bronze or black. The question is can I just replace the stylus or do I have to replace the whole cartridge?
fatboyslimfast
fatboyslimfast's picture
Re: Replacement stylus or cartridge?
You can upgrade the stylus - all styli in the 2M range are interchangeable, but it's not a full upgrade.
There are tweaks in the Bronze and Black bodies that aren't present in the Red or Blue bodies.
I suppose that what I'm saying is that if you stick a Bronze stylus on a Red or Blue body, you will have about 85-90% of a Bronze, not 100%.
But it's £75 cheaper than a whole Bronze...
__________________
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
gbhsi1
gbhsi1's picture
fatboyslimfast:
Thanks for he reply fatboyslimfast, that 85-90% sounds good to me Smile
martystone44
martystone44's picture
this helps me a lot
Lost Angeles
Lost Angeles's picture
fatboyslimfast:
You can upgrade the stylus - all styli in the 2M range are interchangeable, but it's not a full upgrade. There are tweaks in the Bronze and Black bodies that aren't present in the Red or Blue bodies. I suppose that what I'm saying is that if you stick a Bronze stylus on a Red or Blue body, you will have about 85-90% of a Bronze, not 100%. But it's £75 cheaper than a whole Bronze...
Interesting!
Is it the same percentage if you go to a black?
__________________
Orbe SE.
fatboyslimfast
It's a rough guide, rather than an absolute measured, but I would expect it to be in the same range.
__________________
Lost Angeles
fatboyslimfast:
Thank you
I spent an hour on the Ortofon web site last week looking for which styli would fit on which cartridge but all I could see was that they recommended direct replacement so this is vey useful to know.
__________________
Orbe SE.
