18 posts / 0 new
Last post
admin's picture
Last seen: 4 days 3 hours ago
Really.. Build your own speakers?
Hey,
Given that you had the time, wuold you rather build your own speakers or just buy a pair..
You know, would you like to make your very OWN with your own design right from wood (or at least from a kit), or just buy a pair of, say, KEFs that you know has all those years of expertise in-built.
IMHO, some of you see good brands, but think hey I dun want 2 Mids, I want 3, and 2 tweeters and a super-tweeter, not just one tweeter, get me? Self-builds give you the freedom to do what you want, but is it worth it!?
If you've built your own pair, why not share some photos with us!?
AJ
toyota man's picture
Last seen: 3 months 4 weeks ago
RE: Really.. Build your own speakers?
 I built a pair of richard allen speakers I think they were called sardanas or some thing like that they had a 12inch 30cm bass 8inch 20cm mid range and a 5cm tweeter they went very load and didn't sound to bad to a young lad of 17 wired up to my trio ka 3300a amp which had darlington power blocks whatever they are I have some 35mm photos I will post when / if I can find them  the tt was a pioneer pl12d with shure m75ed cables bell wire and free bees I used 20mm chip board and I used some old blankets to add extra damping to the fibreglass that came with the kit it may not of been fibre glass it was white and looked like fibre glass that was some years ago  making the removable tygan grills was fun I could only get red which was nearly as loud as the speakers
Musical Fidelity M6500i, Musical Fidelity M6 CDP, Musical Fidelity Encore Connect, ATC SCM 40s, Cord Chameleon plus XLRs, Tellurium Q Black speaker cables.
Anonymous's picture
Awesome man, yeh you'll have to post your photos for sure, I'd love to see them!
Nothing more satisfying eh,
davidf's picture
Last seen: 3 days 6 hours ago
I can imagine the pride in building your own, but I'd rather save the time and just buy some that I like. At least I'll know they've been made to sound as good as possible. Building your own, you'll never know how they measure unless you own the right equipment.
the little audio company
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / cyrus / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
steve_1979's picture
Last seen: 5 days 19 hours ago
I designed and built a pair of 500 watt 15" car subwoofers with my dad when I was a kid. It was both fun and educational. They were just simple sealed enclosures with a bit of internal bracing so nothing special. I used the golden ratio and the manufacturers recommended volume to calculate the dimensions of the enclosure. They sounded pretty good too although nothing exceptional.
So as a bit of fun in my spare time then yes I already have built my own speakers and might even consider having another go one day if I had some spare time.
However. As far as sound quality goes if I wanted a pair of hifi speakers to use every day at home I'd rather let someone who's qualified and experienced at speaker design do the hard work as I'm sure they'd be able to do a better job than me.
Crossie's picture
Last seen: 3 months 1 week ago
Built my own. I would recommend it as the best bang per buck route. Pictures here : http://www.whathifi.com/forum/your-system/diy-speakers-bass-extenders
Cheers  :cheers:
Just because you are paranoid does not mean that they are not out to get you.
RobinKidderminster's picture
Last seen: 3 months 3 weeks ago
Yup - back in the 70s I build some 12" woofers (given to me) added some tweeters and crossover and loads of chipboard. Covered in Formica they certainly went low and sounded pretty good. 3' tall and 2' wide they were decent beasts. Then Goodmans Mezzo Twin kit. More accurate but smaller and neater they never quite gave the same kick. Sadly no pix but I would love to get them back to hear how they sound in comparrison to my modern kit. My original Leak amp gave way to a Rotel. I also made the plynth for a garrad 86SB turntable which I still use (occasionally). Good fun but not for the feinht hearted.
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
matthewpiano's picture
Last seen: 3 weeks 6 days ago
I would love to be able to build my own speakers but I don't have the wood working skills to do a nice job, and off-the-shelf speakers are so good that I'm not sure it would be worthwhile.  Would be a fascinating project though.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
hammill's picture
Last seen: 6 days 16 hours ago
Goodmans Mezzo Twins were my first speakers and lasted me from when I was 16 until I got my first job after uni and could afford to buy something a bit posher. They were covered in fablon, so did not look special, but they sounded pretty good and the cabinets were over engineered so could easily be used as a step stool when required.
cs2011's picture
Last seen: 6 days 2 hours ago
AJ20011 wrote:
Hey,
Given that you had the time, would you rather build your own speakers......
AJ
I am about to embark on just that !
I have built my own speakers in the past, with varying degrees of success. You do need to have sufficient knowledge of accoustics, electronics, and driver characteristics, as well as reasonably good woodworking skills, if the end result is to be acceptable.  In the past, getting the acoustic design right has always been a bit hit and miss. Without the test and measurement facilities which the commercial speaker manufacturers have, you are really up against it.  However, there is now (at last) very accurate speaker simulation software available which eliminates most of the guesswork, so you can be confident that what you design will work as expected.
bluedroog's picture
Last seen: 2 weeks 4 days ago
As it is I’d rather just buy a pair made by people who know what they are doing. That is because I only have room for one system, can’t afford to go wrong with DIY, don’t have the space of equipment to build and neither the time or expertise.
That said I’d love to give it a bash one day, perhaps when I’ve the space for a second system and a bit more money to throw at them and a little workshop….
Anonymous's picture
That's great man please upload your speaker pictures Wink
shooter's picture
Last seen: 2 years 10 months ago
http://www.pvconsultants.com/audio/frdgroup.htm
http://www.speakerbuilding.com/software/
http://timberworx.net/
Anonymous's picture
I built a pair of Cyburgs Needles:
http://www.jrbham.btinternet.co.uk/needle/index.html
A lot of shortcomings but they had the best imaging I have ever heard, you could walk around the instruments if you wanted.  Shame SWMBO didn't like the rough and ready MDF finish that I never got around to veneering...
Considering the drivers cost €12 each it was astonishing!
edit: actually the speakers I made were ther version with the Tangband drivers (which look mega cool thanks to their aluminium phase plug).
CnoEvil's picture
Last seen: 2 weeks 1 day ago
My first speakers were homemade....built in 1977 during design class and used RS drivers (8" woofers + tweeters) and crossovers. I stuffed them full of acoustic foam and fiberglass on the inside, and sticky backed vinyl stuff with a wood pattern, on the outside......They did the job for a while.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
Overdose's picture
Last seen: 2 years 2 months ago
Having just seen the 'finished' article in that link, I'm not suprised. :O
Pages
Log in to post comments
