Mono output being produced through stereo speakers?!?
5 replies [Last post]
onemeg
onemeg's picture
Hi. I've just realised that my Rotel RB/RC 970bx's are producing mono sound but playing through both speakers. Or at least, I think they are. The power amp has a mono switch if bi-amping but it's definitely on stereo. The volume is full and the sound is fine, it's just that music is coming out of both speakers but it seems that it's the same channel coming out of each,. When I turn the balance either both speakers go off or both come on - rather than one or the other.... Any thoughts as to what the problem might be?
JoelSim
JoelSim's picture
Re: Mono output being produced through stereo speakers?!?
Check that you've got all the plugs in the right sockets
__________________
Unison Research CDE, Leema Tucana 2, Kudos C2 and some cables.
bluetorric
bluetorric's picture
Yes, sounds as if its out of phase, swap the plugs on one speaker only.
John Duncan
John Duncan's picture
Sounds broke to me. I can't think of any arrangment of cabling that would produce this in a working system?
May just be the mono/stereo slider that's not connecting properly though. Might be worth cleaning/replacing.
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Andrew Everard
Andrew Everard's picture
Can't remember off the top of my head, but has the preamp got two sets of preouts - ie to feed two power amps? From the description of your problem it would sound like the power amp is only connected to one channel of the preamp - ie to both the left outputs or both the right. That's the only way the balance control would have the effect you describe.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
John Duncan
Ooo you might be onto something here, because it does, according to the owners manual:
http://www.rotel.com/UK/Products/ProductDetails.htm?Id=366
__________________
