MARANTZ CD63=MKII KI SIGNATURE REPLACEMENT
11 replies [Last post]
APIQUE
APIQUE's picture
Hello
I own a CD63 KI signature since 1999 and now I am considering replacing it because I had problems with the transport last fall and it was already quite difficult to find someone reliable to fix it. On top, he said that it was very difficult to find parts. The thing is that I have read so much about DACs that I am a bit confused. I am considering 2 options: 1-Buying the micromega mydac and add it to the system 2-Replacing the Marantz by a Cayin CD 50-T player (Special offer 685 pounds) The second option is the recommended by my local shop mainly because if I buy the DAC and then the transport fails or the laser, then I will have to spend more money. Which would improve more the quality of the sound? My system is a Lavardin IS amplifier, Marantz CD63MKII KI signature and PMC LB1 speakers. Cardas interconnects used. Thanks everybody
BigH
BigH's picture
RE: MARANTZ CD63=MKII KI SIGNATURE REPLACEMENT
I have 63SE and I was thinking of upgrading or changing, the advise I got from many people was keep what you got or get a Blu-ray player and a DAC. You could look at the Marantz 6004 with a DAC. Do not know the Cayin is that American? Can it be serviced here or are you in the USA?
One other option is the Marantz SA KI Pearl Lite Ive seen them around for just over £600 new recently.
drlindgren
drlindgren's picture
Worth quickly checking what the problem is with your transport.
Reason I ask is because I have tended to keep my CD players until they are really old, and the thing that 'fails' for me is the transport.  However, in my experience of 2 CD players (a Marantz, and a NAD), the problem ultimately came down to the fact that the transport drive belt (which is a bit like a small, black rubber band) had got old, stiff and a bit loose, and was no longer firmly driving the transport.
Was not hard to replace the drive belt (replacement, bought from eBay was pretty cheap), and CD player works beautifully again.
Your problem might be completely different, or you may just want a good excuse to splash the cash on some tasty new kit  Wink, but I thought potentially worth me mentioning this.
MajorFubar
MajorFubar's picture
Ah, that old chestnut  ohhh sure They usually roll that one out when they're trying to get you to spend more money than you originally planned. CD-63 mk II was, in its various vanilla, SE and KI Signature guises, one of the biggest-selling CD players of all time. There really is no shortage of used players going cheap to either replace yours or raid parts from. As above, the biggest culprit is a rubber drivebelt that's seen better days. They also benefit from having the laser cleaned as well (easy to do with the lid off and a cotton-bud/q-tip dipped in isopropyl alcohol).
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
Inter_Voice
Inter_Voice's picture
For CD63 the parts are extremely easy to find.
If the problem is on the belt buy from here: http://www.ebay.co.uk/itm/280884428428?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
If the problem is on the laser buy this: http://www.ebay.co.uk/itm/Marantz-CD63-MK2-Ki-Laser-Mechanism-CDM12-1-CDM12-2-/150990996013?pt=UK_AudioTVElectronics_HomeAudioHiFi_CDPlayerSeparates&hash=item2327c3c22d
There are tons of discussions about modding the CD63 and if you are good at DIY then see this link:
 http://www.diyaudio.com/forums/digital-source/54009-marantz-cd63-cd67-mods-list-1905.html
From my experience the SQ of your stock CD63 KI Signature is better than today's CDP of 800 pounds.  If it is properly modded, it sounds better than anything more than 3000 pounds Money mouth   Think carefully and bring along your CD 63 for an audition/comparision before you make your decision to buy anthing new.
__________________
Enjoying music from a dream hi-fi system in a well treated room.
APIQUE
APIQUE's picture
Thanks everybody. I have been looking into lots of forums and everybody agrees with the difficulty of getting a better CDP without expending a lot (my budget is 800-900 pound top) Cayin has the attractive to have some valves built in, so I am curious about it. I see now that the most sensible thing is to get my Marantz and compare it to the Cayin and decide maybe into modding it I´ll have a look to those links. Thanks
shafesk
shafesk's picture
APIQUE wrote:
Hello
Hi there, well I think you have done a good bit of research. I hear the Cayin CD 50T everytime I listen to my brothers system and am quite familiar with it at this point. I also happen to own a cd 63 k2 too. I really love the Cayin, its solidly built and sounds very smooth indeed. Our dealer told us that if we wanted to step up from the CD 50 then we'd have to spend considerably more. It does sound warmer than the CD 63 though. Be sure to buy from an authorised Cayin dealer though, cd players are something I wouldn't buy without warranty.
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
BigH
BigH's picture
There is a company in the UK that sell 63 II SE and KI and upgrades them as well, just google and you should find them. The tray( drawer) tends to be the thing that fails, but you can get parts and fix yourself or get someone to do it for you, the parts are cheap around £10? My tray sticks sometimes.
BigH
BigH's picture
Has anyone heard the Marantz SA KI Pearl Lite and the 63 KI?
Alears
Alears's picture
Yes I have. Used to own the CD63 Ki Sig, my brother now has it and it is still going strong.
Was auditioning the Pearl Lite when was offered a very good deal on a SA15S1, which I considered superior to either of those mentioned, so I got that instead. Smile
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
APIQUE
APIQUE's picture
Hi, At least I find someone who has listened to the Cayin. That was what the official dealer told me, that it was warmer than the CD63 KI and considering it is an special offer, 850€ (price is 1100€)about 685 pounds I didn´tknow what to do. Mine i also have started to feel that it is sounding more somehow metallic, voices are not what they used to be. And this feeling I have it a little bit after the repair on the transport last october. Maybe they messed up something? So I was cosidering a DAC or changing the CDP. Yours is a good input, at least I know the dealer is not trying just to sell.... I´ll take my CD63 and do a comparison. Thanks
BigH
BigH's picture
Here is a review: http://theartofsound.net/forum/showthread.php?t=9476
I would check out the servicing situation in your country as well.
