Kef R500 vs R700.....
Does anybody know what the real difference between these floorstanders is apart from £500 in price? I have the R500's on home trial at the moment because my R300's developed a fault. I have the option to upgrade to them for only £350 instead of replacing my faulty 300's. I may well do this because they sound great, but am curious what the extra £500 on top again would get me if I decided to "double upgrade" for the R700's. I know it is ultimately down to what my ears say but I thought I would gather opinion before going through the hassle of boxing everything up again.....
Whether it's worth it in your situation, may depend on the size of the room and its acoustics.
I have heard the R700s but not the R500s, though I'm familiar enough with various Kef models to make a reasonable guess (until someone like David rolls up)
They will sound very similar, but with greater scale (bass)....which should make the speaker sound gutsier. The R700s did sound very good (in a mid sized room), and had surprising bass for their size.
Thanks Cnoevil,
My room is 6m x 5m. The speakers back on to the 6m wall, 3m apart with approx 30cm behind them. I sit centre opposite appox 4m away. Smoking jacket, slippers, glass of good red. You know the score.
In that case I would go for the R700.....but try first if poss.
I went through the same thing with IQ5/IQ7/IQ9 and then 203/2 vs 205/2.
As you get more bass, large scale or bass driven music just sound so much better...it's very hard to go back after hearing the bigger brother.
The impact on AV is less imo...as the centre does so much of the work, and the sub takes care of the deep bass.
Hi Gazzip,
can you tell something about R300 and R500 inside a 180 square feet room? What is yor expiriece regarding the room size matching to those two models?
Best regards
In a 6m x 5m room, I'd definitely be looking towards the R700's. The R500's will still perform well, but you'll want something with a little extra headroom, and something that can effortlessly fill the room in the low end department. The R700's will reach deeper due to their larger cabinet volume (not vastly, but noticable), and they'll also shift more air due to their larger bass drivers. Effectively, the R700 is a floorstanding version of the R300's. They'll also allow your Mono X's to reveal their true abilities too.
As always, give them a try
So I've had the R300's, R500's and R700's all on extended home auditions and this is what I have found so far:
R300's - £1000 - Amazing soundstage. Great bass but some fiddling with rear port bungs and positioning in relation to the rear wall was required to focus it. Great with vocal music but pretty dam good with anything you throw at them really. They do however get a bit confused with complex pieces of music.
R500's - £1500 - As above but with more oomph. Bass is deep and controlled. Also there is better separation within the soundstage and less tenancy for the presentation to be cloudy when the complexity increases. Female vocals are amazing but the metal drive units are exposed by some male vocal recordings which can lead to a slightly "metallic" and unnatural sound. This is a very small issue but it has been grating during prolonged listening periods. Not fussy about positioning.
R700's - £2000 - Hmmmmm. I only got these because I was so impressed by the R500,s and wanted to know what an extra £500 would get me. The bass is big. Really big. Could be weaponised with a few tweaks. Mind you it should be good coming from floorstanders weighing 27kg each. However after 30 hours of running in day and night I am feeling quite cold about these boxes. The incredible soundstage created by the much less expensive 300'sand 500's seems to have been lost in translation to the bigger cabinets, or maybe visa versa? Also the metallic male vocal issue is much more prevalent here.
All of the above leaves me more confused than when I started the auditioning. I am tempted to revert to the 500's but am also wondering about the 900's. Will going to the top of the range just give me more of the R700's traits or are the 900's in a different league?
Do you have to go with Kef.....What about Spendor or Proac.
Maybe it's a certain size of speaker that suits your room acoustics.
i was in the similar boat as getting a pair of speakers, my setup consist of roksan kandy l3 amp and cd player, speakers are a tannoy mx3 floorstanding, been decorating recently and paint spattered on my speakers and also had some damage to them, cone disfigured, any way it was time to get another pair as i find the tannoy bass light, went to the hifi dealers and demoed a kef r300 r 500 and r700, i found that there was a step up upgrade to the sound when you moved to different kef speakers, the r 300 terrific timing vocals, and sweet treble, the r500 had the same but some scale, i was sold on the r700, those were the daddy!!
Am waiting for them got them on a piano black finish and the dealer did me a deal £1700 for the r700 !!
P.s Lied to the wife i got them for a £1000 not £1700 not worth the aggro if yu tell them the truth!!
I see you are now very happy with the R700s, so what changed....was it a "run in" thing or the Bryston amplification? I ask as I'm suggesting these to Wishtree, who was a little put off by your initial assessment (above).
You now have a wonderful system, and am right in thinking that the SBT is a transport for the built-in Bryston Dac?
Thanks Cno! Yes, please let us know what has changed as it might be good learning for me about what to look for.
BTW.. I took a demo of KEF R700 (cno, I am converted to KEF R series, almost!). It is not much of a demo but heard few songs with a Marantz Pearl Lite Amplifier. Definetly there is magic there!! I was only focussing on the top end smoothness and it was really really smooth. I heard a track which I am very familiar with and there is an airy smoothness on treble..
Also, I got this nice shop to play the B&W 804D with the same Pearl lite amplifer and I can say that the smoothness on top end of R700 is not miles away from the 804D. Ofcourse, the 804D are in a different league altogether given the double or more pricing.
If I can get enought funds then it will be 804D, otherwise it will be the R700s.
BTW, Gazzip, which color did you get?
That's great. I suspect they will sound better again with the Classe. The best compliment I can give them, is that they sound closer to the Refs than the price would suggest.
Closer to Refs? That is nice to know. This nice shop is getting renowated right now and 4 weeks from now, they are going to do a side by side demo with KEF blades and R series (I think it is because of some of the blades tech got trickled down to R series, I guess). It would be a delight to listen to both and possibly I will take my amp and check how it works out (provided I do not already buy the speakers by then
Hi Cno and WishTree,
Piano black is the colour. You chose well WishTree, they look amazing. My initial disappointment was due to a restricted soundstage. Not surprisingly really considering the ability of the R300's I had before them and their incredible ability to position instruments. However given time the 700's scale and range have won through. The change of mind followed a good run in, I would say a week on low volume, all day every day.
The Bryston stuff is a pre/power combo that sounds lovely. It has taken me a couple of listening sessions to "get it". Initially I wasn't bowled over by what I perceived to be a lack of "HiFi" in comparison to the Cyrus stuff I previously owned. However, I don't remember tapping my feet and bobbing my head like a strutting chicken to the Cyrus kit, so something pretty cool has happened.....
The R500 has 2 x 130mm (5.25in.) bass drivers, while the R700 has 2 x 165mm (6.5in.) bass drivers. The R700 also has a larger cabinet. So the difference should be deeper bass.
M-Audio USB Transit->Benchmark DAC1->Beyerdynamic DT880 (600 ohm) / AKG K701
