6 posts / 0 new
Last post
DocG's picture
Last seen: 12 hours 47 min ago
Digital transfer: USB - SPDIF - I2S - LAN - Wifi... Oh man! Too difficult!
I just cut this little extract out of the USB cables expensive v cheap thread. As my question is different, broader and - well yes - more interesting than the USB-price-per-metre-conundrum  ;), I thought I should start a new thread on it.
Covenanter wrote:
andyjm wrote:
Covenanter wrote:
 The actual timing of the 1s and 0s doesn't matter either because the receiving device can store the incoming signal in a buffer and take it out at the correct rate.  This is why CD players in cars don't suffer from the movement of the car.
Does your DAC do this? Very few do.
Most rely on slaving their clock to the input bitstream.
Yep I know.  I just mentioned the possibility because it is there.
Chris
Now that is a topic I'm struggling with: clocking and reclocking of digital signals. As far as I understand it (toddler grade - I apologize), a DAC with async USB just pulls the data in and clocks the signal itself; an I2S cable [or I2S connection in a CDP] transfers the raw data ànd the clock signal separately; while a SPDIF (coax or optical) just beats data and clocking together and transfers it as one signal; and that's where jitter kicks in, right? Or do some DACs also reclock the SPDIF signal (and if so: examples?)? And how about network players? :? As I said before: Oh man! Too difficult!  :help:
Downstairs: Bluesound Node2 -- DEQX HDP-3 -- 4 x Hypex NC-400 -- modded Magnepan MMGs
Upstairs: NAD M50 -- Devialet D120 (SAM) -- KEF LS50
Head-fi: in progress...
chebby's picture
Last seen: 3 hours 15 min ago
RE: Digital transfer:
Why worry?  You don't have to build it to enjoy it.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
DocG's picture
RE: Digital transfer: RE: Digital transfer:
No, but it says something on the relative importance of the transport you feed your DAC from. Would be a pity to pay big money for a DAC, which then highlights the weakness of the disk spinner...
Overdose's picture
Last seen: 2 years 2 months ago
An engineers perspective
An engineers perspective HERE.
Good quality audio that is audibly transparent is neither difficult nor expensive to acheive.
Have a look too, at the ODAC on his website.
DocG's picture
RE: An engineers perspective
Thanks for the link, OD. It's quite extensive (and rather difficult for a layman - but then again: I asked for it :grin:).
All in all, I remember the ODAC is a USB-DAC (no SPDIF, never will), it won't be expensive and it's due in a couple of months.
Overdose's picture
There was a desktop amp and DAC project in the pipeline, but unfortunately, this has gone quiet. The ODAC is supposed to be rather good.
It is available now from a few online outlets. The UK one is being sold for just under £90.
Log in to post comments
