1 post / 0 new
adp72uk's picture
Last seen: 2 years 3 weeks ago
Sky broadband router / Airport Express / Airport extreme base station.
My wireless network is provided by my Sky router, I have two airport express on two different hi-fi.  My laptop supplies the tunes.
My problem is that the signal often drops out on one or both hi-fi, making listening to music painfull!
The router is a reasonable distance from both express' and I am unable to move it closer.
I have a cunning plan though..... If possible I'd like to disable the wireless, use the sky router as a modem only and plug in an airport extreme to create what I believe will be a stronger, wider reaching wi-fi network.
Has anyone done similar??  Will my plan work??  How do you switch the wireless signal off??
All advice will be gratefully received.
