Noisy NAS ?
16 replies [Last post]
canada16
canada16's picture
Hey bought a Dlink DNS-320 and had it for about 6 months, amazon have agreed to return.
The problem is, the fan wont stop, it goes off all the time, and stays on, and its not the quitest.
If it went on only once and a while I would not mind, but cant leave it on, if I am sleeping ect.
Do all NAS's boxes do this, I even left the lid off to try cool it down, and it still kept going off.
No settings to stop fan, or anything.
What would you sugest, remove the fan and invalidate the warranty, or return and buy something else.
Got 70.00 to spend, would prefer something I can HDD to, but was looking at the WD 1TB one for 70.00 in currys.
__________________
Living room: Monitor Audio RX6-Centre -RXFX-
SVS PC13-ULTRA-WOW!!!!! Surprised
Onkyo TX-NR818, Panasonic 50G20, PS3, Sony BDP-370 - Macbook Pro i5 For HTPC.
BEDROOM- LG 32LE4900 Pioneer VSX-921 MA- R90HD & 225HD, RSW12
Rocky Mountain Vertex Mountain bike.
The_Lhc
The_Lhc's picture
Online
RE: Wi-fi
Remove the fan? It's there for a reason you know.
__________________
No signature worth mentioning...
TechMad
TechMad's picture
RE: Wi-fi
Try blocking port 6881 (the standard p2p port) on your router, so ur NAS doesnt receive incoming traffic and keep waking up.
Other people seem to say it fixes the bug on the dlink forums.
http://forums.dlink.com/index.php?topic=37696.0
__________________
Samsung UE55C8000, Denon 4311, Denon DBP-2012UD, PS3, Playon!HD mini 2, KEF XQ-40, AE Pro Active 5.1
Samsung UE46C9000, Samsung BD-C6900, Yamaha RX-V1067, HDX-BD1, Phillips Streamium 2900, KEF 2005.3
2x8TB NAS
scene
scene's picture
RE: Wi-fi
A lot of NAs use bog-standard cooling fans, that are cheap and noisy.  These can usually be easily swapped out for quieter fans that greatly reduce the noise - these often cost around £5, a good investment.  However, this does invalidate your warrenty... Also, a number of NAS allow the user to tweak fan min/max speed.  This can reduce the noise levels as well, but can result in a hotter unit with reduced lifespan. However, combining this with a slower rotating quiter fan offsets this.  The important thing is to match (or overmatch) the cps of the fan.
Another, much, much more expensive option is to swap to flash disks - these can often be run without fans.
IIRC the Buffalo LinkStation mini is fanless and QNAP have a range of fanless NAS.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, Sonos ZP90, AE Compact-1.  AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A.  2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90.  Cables: That Cable HDMI, Chord Crimsons, CAT6 backbone  Sonos S5s in the bedrooms
canada16
canada16's picture
RE: Wi-fi
On the setting there is a Max and auto and mid, but not min, tried them all and it still goes off.
I think its either buy a new fan, or return to amazon and try another make.
Thanks guys.
__________________
Andrew Everard
Andrew Everard's picture
RE: Wi-fi
Or of course put the NAS somewhere you can't hear it. Just a thought...
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
NSYGrinner
NSYGrinner's picture
RE: Wi-fi
That's what I had to do with my ReadyNAS. It is now on a shelf under the floorboards in the hallway. It was in the cupboard under the stairs but could be heard in the kitchen, Only faintly but once the noise was picked up then it became annoying.
Andrew Everard
RE: Wi-fi
Hmm... My NAS drives sit on a shelf on the AV rack in plain view. Never heard a peep out of them yet.
__________________
The_Lhc
The_Lhc's picture
Online
RE: Wi-fi
Ditto, if my NAS makes any noise I've long since stopped noticing.
__________________
Ravey Gravey Davy
Ravey Gravey Davy's picture
RE: Wi-fi
If it is under the downstairs floorboards, I would be wary of damp and particularly excessive dirt/dust carried/stirred up by the through draft (from the airbricks).The fan will be particularly attractive to these guys.
Andrew Everard
RE: Wi-fi
Unless, of course...
__________________
Paul.
Paul.'s picture
Online
RE: Wi-fi
My Nas at work sounds like a Harrier taking off when doing backups.  I usually just turn the music up.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
Dan Turner
Dan Turner's picture
RE: Wi-fi
My ReadyNas makes a racket, I lasted about 3 days with it in the lounge and had to relocate it to a cupboard.
Andrew - I'm amazed yours is so quiet that you don't hear it even in the same room - may I ask what make it is?
__________________
Sonos ZP90 / CA 751BD / Sky HD / Apple TV
-> AVI ADM40
-> Panasonic PDP50G10
canada16
canada16's picture
RE: Wi-fi
I blocked the port, and it seems to only go off now and again and turned off P2P.
Thanks for telling me that, if all your guys NAS are going off, I might just leave mine then, thought mine was faulty, or garbage.
If you have a NAS in the same room as you and You cant really hear it, please let me know, what make and model it is, but can only spend 100.00 MAX!
Thanks again
__________________
Jammoe
Jammoe's picture
RE: Wi-fi
Netgear ReadyNas Duo. About four months old.
Am currently sitting on the sofa that the NAS is sitting behind and can't here it at all. The fan goes for about five seconds on startup / reboot, but other than that it's unnoticeable.
Have just this second played a film from it with volume muted to test. Still not a murmur.
__________________
Main System - Denon DBP-2012UD / Sky HD / Popcorn Hour / Squeezebox Touch - Panasonic 65VT50 - Pioneer VSX-LX53 - B&W 685/686/HTM62/ASW610
brendonw
brendonw's picture
RE: Wi-fi
Synology 211j is v.quiet.
The ReadyNAS I had before that was the same.
