Please help me reduce static
5 replies [Last post]
marplesl
marplesl's picture
Hi all,
In the last couple of weeks I have purchased myself an RP1 and thrilled to have got back in to vinyl but the one thing which bothers me is static, it seems to be worse on brand new vinyl but is also noticeable on pretty much everything I play. I was hoping the guru's on here could provide some advice on the best ways to reduce this. I have on my xmas list a Disco Ant-Static cleaner and have also purchased myself some anti-static inner sleeves so I guess this will reduce the static but was wondering whether there was anything I should look at.
__________________
RP1 Turntable, Rega Apollo CDP, Mira Amp and  RS3 Speakers...
I guess I'm a bit of a Rega fan
Sospri
Sospri's picture
RE: Please help me reduce static
I have great results with the  zerostat, does the job a treat.............
__________________
Logitech Touch > digital input > Naim Supernait >Chord Silverscreen >Spendor SA1s.
Naim Stageline > Inspired Rega P7 Rega Exact.
 Beyerdynamic DT 880 Pro
floyd droid
floyd droid's picture
One of these will help you a little me old china. New vinyl is a bit of a nightmare in the static dept these days.
Change your xmas list from a disco anti stat to a propper rcm and cross your fingers.
RobinKidderminster
RobinKidderminster's picture
I use a felt mat. Homemade for pence. Never siffered. Worth a try? And an antistat cleaning brush/pad earthed to base
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
floyd droid
Oh gawd. I was going to go into the drain wire dept but thought better of it. Well Rob,i will leave you to dig yourself out of that one,lol.
DandyCobalt
DandyCobalt's picture
I had really annoying static problems with my P3-24, before I upgraded things like the mat, platter and subplatter (the Inspire package for the acrylic platter/mat, Isokinetic for the subplatter).
Now I have no static problems, so something in that set of upgrades did the trick. Might be worth a bit of experimenting.
We also got a room ioniser (Heaven Fresh HF200) online from Boots. That may also have helped.
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
