5 posts / 0 new
Last post
willgaunt's picture
Last seen: 1 year 4 months ago
Ortofon 2M black vs Super OM40
Looking for opinions on above. Not that I can afford the 2M black at the moment, just wondering if it might be worth saving up. And does anyone know if the 2M 78 stylus will fit on any of the 2M cartridges? Thanks.
MF M1CDT/Primare Pre32 (+MM30)/Primare A34.2/Clearaudio Concept/RFC Raptors/MF X-Can(upgraded)/Sennheiser HD650 + Shure SRH940. Getting there!
Al ears's picture
Last seen: 1 day 9 hours ago
RE: Ortofon 2M black vs Super OM40
Hi willgaunt. According to the Ortofon website the answer is no.
http://www.ortofon.com/products/replacement-styli/stylus-2m-78
the 78 stylus is preferred fitted to it's mono cartridge.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
KeithT's picture
Last seen: 2 months 3 weeks ago
Yes it is.  Smile  Worth saving up for.
From a very happy user!  SmileSmile
Henley's picture
Last seen: 1 year 5 months ago
For the record.
The 2M 78 stylus will work well with any of the 2M series.  However, the output will be in stereo whereas most 78's were recorded in mono which is why Ortofon suggest the mono body.
The 2M Black is a huge step up from the OM40, both in diamond and body material.
UK distributors for Pro-Ject, Ortofon, Roksan, Unison Research, Lehmann and Reloop
Here to help.
willgaunt's picture
Thanks for the info. Clarifies what Ortofon told me, which was less illuminating than I'd hoped. I'm assuming that the 78 stylus on the 2M body would give a similar result to using the equivalent stylus on the OM body. If so it will do for occasional use - I have a wind-up machine in the corner that suits 78s better anyway!
Log in to post comments
