2 posts / 0 new
Last post
admin's picture
Last seen: 2 days 5 hours ago
Volume difference AMC vs. Arcam
I´m wondering a bit about my new change of amp and the output level.
I´m not a master on luring what the exacts specs means for my setup.
The comparisson is between the AMC XIA and Arcam A85
AMC specs:
Input Sensitivity for 1W/Rated Power into 8 ohms:
High level inputs.........................................................................................23mV/150mV
Input impedance:
High level inputs..........................................................................................20K ohms
Tone control range:
Bass at 100Hz......................................................................................................+/-10dB
Treble at 10KHz.................................................................................................-8/+11dB
Overall feedback................................................................................................26/29dB
Signal to noise ratio(ref.1W/8 ohms):
High level inputs "A" WTD.......................................................................................88dB
Phono inputs"A" WTD............................................................................................80dB
Separation 20Hz-20KHz .......................................................................................>65dB
Arcam Specs:
Continuous power output, per channel
Both channels, 8Ω, 20Hz–20kHz 85W
Single channel, 4Ω, 1kHz 140W
Distortion, 8Ω, 80% power, 1kHz 0.005%
Inputs
Line and tape inputs:
 Nominal sensitivity 250mV
 Input impedance 22kΩ
 Signal/noise ratio (CCIR) 105dB
Tone controls, max. boost/cut ±12dB
These are the specs which both look different and sound very different. On my AMC i just needed to turn maybe 1/4 on the volume wheel and then it was really loud on the Arcam i have to turn almost the double of that before getting to same level. My speakers are btw heybrook hb1. Is it because of the db sensitivity?
Mooly's picture
Last seen: 5 months 7 hours ago
RE: Volume difference AMC vs. Arcam
The raw numbers seem to show the AMC was more sensitive.
In practice you have nothing to worry about and its impossible to give a definitive answer because it all depends on the gain structure and how the gain is split between the preamp and power amp sections. Having all the "action" occur during the first few degrees of rotation of the volume control is no clue as to how powerful or how loud the amp is and can be detrimental because fine control is less easy.
You have nothing to worry about.
Log in to post comments
